meatfestival
- Apr 5, 2005
Hopefully this explains why I've had so many BSODs the last couple of days.
It's iTunes for Windows, does anyone think it'll actually work without issues? Come on... get real. I have absolutely no reason to doubt Apple is doing things to intentionally cripple their products when used on the Windows platform so people will become so angry about it they'll figure "It must be Windows, so I'll go get a Mac..."
Please... Apple knows precisely what they're doing, second by second.
Doubt it, that would be a dumb business move on the part of Apple.
Well, I use MediaMonkey. Very powerful player / ripper / organizer, and with 3.0, it can handle 100,000 songs...![]()
The first thing you see is a notice from Apple Software Update. It promises an update to iTunes+QuickTime and says nothing about any other software.
Opening the folder where Apple Software Update stores its temporary files reveals whats really going on. The download consists of five installer packages and a master setup program.
One is a USB controller update, which is apparently used when connecting an iPod or iPhone to the system. On my system, this driver file was copied to the system but was not installed until I connected an iPod Mini via a USB port.
the whole, you need itunes to use an ipod sucks. i think i will buy my kids a ms zune next time. any other mp3 player suggestions. ijust want to copy and paste my mp3s into the device and play them i dont want some program forced on me to babysit me.
I know this is going to sound rude, but maybe some of you don't have your computer setup properly. I've been using a 1G nano and iTunes for about three years now and have not had any problems at all. I installed ver 8 tonight, plugged in the nano and wammo...my computer is just fine. Quit blaming the software and start looking are your install. No one is perfect. Also, I'm not an apple fanboy. The only Apple equipment I own is the nano and it will get replaced when it doesn't work anymore.
My buddy has a first day xbox that's still running fine therefore everyone else who's had the RROD must be doing something wrong.
Uh yeah, because every computer in the world is the same and installs should be flawless..
Say, that sounds awfully similar to Apple computers!
I've had iTunes on three different computers and two different notebooks. All different hardware and software. Never a problem for me. I still say PEBKAC.
At what stage of the automated process do you suggest people are screwing up the install then? It's impossible to screw up an install where the software does it from start to finish for youApples and oranges. RROD is a known issue that MS admits to. Also, most people don't install all the software on their Xbox as it's a console.
At what stage of the automated process do you suggest people are screwing up the install then? It's impossible to screw up an install where the software does it from start to finish for you![]()
I've been avoiding installing Quicktime and iTunes for years now, cause I don't want their additional crap installed on my computer.
I have to disagree. I mean, back with XP, I cannot tell you how many BSOD crashes I had that were due to a bad driver, and a simple reinstall of the driver fixed it.While I agree that iTunes is a bloated piece of shit that I would never install on my machine, a BSOD is indicative of a Windows problem. Granted, the iTunes software must be pretty broken to cause such a catastrophic reaction from the OS, but if the OS is properly isolating application level executables, the worst thing that should happen is that the application crashes, or slows th machine to a crawl.
This is a case of an iTunes bug exposing a Windows bug.
The OS should isolate the application in such a way that if the application tries to do something it's not allowed to do, the OS will intercept it, and handle it gracefully.Wrong. BSOD can be caused by software interfacing the operating system and/or it's kernel improperly.
The point that was made by Modred189, however, stands. There is always the possibility of a bad third-party driver.
I dropped iTunes about a year ago after I had enough of it and couldn't take it anymore. It got to the point where for some reason I would go to sync my iPod, and it would take literally overnight, if not longer, to sync one or two albums, and cause everything else running to behave abnormally. I did some research, and ended up switching to MediaMonkey, and haven't looked back since, and now refuse to put iTunes on my computer. I love MediaMonkey, and it syncs my iPod better than iTunes did. All I have to do is plug it in, hit the sync button on MM, and I'm good to go. No apple apps on my computer since then, except for QT Lite.
I never stated that viruses don't or shouldn't exist. Nor did I claim that bad software couldn't be written. In fact, I stated the opposite. However, the scope of damage that the virus does is limited by its level of access to the system. A virus executed at the user level can do as much damage as the user can. If a virus executed at a low-privilege level manages to do something that is supposed to be reserved for a high-privilege level, then it's taking advantage of a bug.So by your definition, virus doesn't or shouldn't exist. Virus is essentially a deliberately written bad software.
[/QUOTE]the whole, you need itunes to use an ipod sucks. i think i will buy my kids a ms zune next time. any other mp3 player suggestions? I just want to copy and paste my mp3s into the device and play them. I dont want some program forced on me to babysit me, like itunes or aol.
