Its alive!! muhahaha
renswic
wooters, got home tonight to find my motherboard back from RMA sitting on our shoe bench, for the past few days ive been preping my LianLi v1000B for build, i got some finish work to do on the wireing, but other then that, shes finished for now *happydance* ill throw up some pics when im done :)
Good luck with the build, I'm about to buy the exact same case as you, and was wondering what your experience with it has been in terms of ease of use and cooling properties.
pictures of the build NOW please since you bothered to make a thread to tell us this!!! :)
couldnt find my cams cable :p
as for the case, its a dream to work with, only probs i had is that with my Ocz Modstream i had to remove a HDD cage and the devider wall
and and for some semi clan wire routeing i hadd to drill one hole(4 pin connecter) and cut a notch out behind the drive cage
installing every thing was like sex with a chick in a coma, quick, easy, and it put up no fight at all
pics i promissed i aint hotlinking them cause i dont wanna resize them:
Boxxes!
http://i33.photobucket.com/albums/d85/rensworkspace/IMG_0001.jpg
http://i33.photobucket.com/albums/d85/rensworkspace/IMG_0003.jpg
http://i33.photobucket.com/albums/d85/rensworkspace/IMG_0004.jpg
case its self:
http://i33.photobucket.com/albums/d85/rensworkspace/IMG_0005.jpg
http://i33.photobucket.com/albums/d85/rensworkspace/IMG_0006.jpg
(^^ look for the notch cut out, its in this pic, lower right hand cornor)
http://i33.photobucket.com/albums/d85/rensworkspace/IMG_0008.jpg
http://i33.photobucket.com/albums/d85/rensworkspace/IMG_0009.jpg
(hmm, i need to get my camera off the booze i see)
ill take other pics in a bit, cleaner ones to
Rofl-Mic-Lofl said:
Hmmm, you got a small toenail on your big toe. ohh.. nice rig BTW :)
heh, i had to doa foot shot, its an unspoken rule here :p and theres a normal toenail the flash make it look small
bored-sarcasm said:
it's a nice case, but learn to work white balance on your camera.
its a cheap (read $40) digi cam from walmart, thats about as good as it gets
