anonyentry
- Nov 6, 2006
Ok, here is the deal.
I have a completely formatted 250gb hitacchi SATA hard drive.
I went to install my copy of xp pro, and it couldn't find the hard drive so the install did not work. I then went to hitachi's site and they said if it's an sata hard drive you need to download the raid drivers from the mobo manufacturer. I have an asus P5S800-VM motherboard.
So I went to: http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5S800-VM
I then clicked raid and downloaded the driver package for windows xp. (This is all on another computer.) After that, I incorperated that driver package into my xp install disk using nlite. I then used the nlite disk and attempted the install again on the other computer. This time, there was a different error message when I went to install it:
Your hard disk was not located properly. Please install the drivers from the manufacturer.
I am stumped. What should I do?
All help is appreciated.
thank you!
thank you!
