weasel2htm
- Sep 8, 2004
I'm attempting to install Vista on a scrounged together machine (specs below) and am encountering an error I'm not sure how to deal with the issue
I get the error "A required CD/DVD device driver is missing. If you have a driver floppydisk, CD,DVD or USB Flash drive please insert it now"
"Note: If the Windows installation media is in the CD/DVD Drive,you may remove it for this step"
So I click "OK" (The only thing it will let me do) it runs a while and says "No Device Drivers were found. Make sure that the installation media contains the correct drivers, and then click OK.
At no point will it let me browse for drivers, or skip the step
This is wiht Vista Beta 2
System Specs:
Gateway Unit with MSI Motherboard
Athlon 950
640MB RAM
8X Samsung DVD-ROM
15GB WD HDD
OptoRite CDRW
TV Tuner Card
SB Live
Nic with Realtek Chipset
System Specs:
Athlon 950
640MB RAM
8X Samsung DVD-ROM
15GB WD HDD
OptoRite CDRW
TV Tuner Card
SB Live
