Issue with POST - Asus A8N-SLI
kaldes
Alright so I have a Asus A8N-SLI board but the machine continues to run POST errors of "System Failed Memory Test" and will not start what so ever.
As of right now its up and running without any errors but restarting or shutting down to reboot is near impossible. What can be wrong?
Here is some of my Cpu-z stats.
Memory Type DDR
Memory Size 2560 MBytes
Channels Single
Memory Frequency 158.0 MHz (CPU/14)
CAS# 2.5
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 7
Bank Cycle Time (tRC) 10
DRAM Idle Timer 16
Command Rate 2T
Only issue I have had was a small voltage spike, but not sure that really has to do with anything.
So I shut it off last night, attempting to turn it on, brings me to the Asus motherboard splash screen, with no post errors and no keyboard input.
Edit: Just kept restarting and its now completely booted up... so strange.
Sounds like power issues. Maybe try just one stick of ram in different slots. I doubt it's that, but it's going to be process of elimination. If you have another PSU to test with, try that first. The mobo may be on it's way out, if that's the case, that's one of the hardest things to troubleshoot.
-D
-D
Thanks bucd, I think its the mobo, but o well for now I guess, I think I rather just upgrade my system a bit.
Try reseating the processor, the RAM, and the power connections from the ps to the mobo.
Reseating the RAM might also help.. but I am leaning more to mobo power connections or CPU needing to be reseated.
