Chris_B
- May 29, 2001
Took delivery of an abit is7e-2 yesterday and have had nothing but trouble. First off anytime i started up the pc i would get the following:
realtek rtc8139(x)/8130/810x boot agent
That would happen on boot and just sit there despite the fact i had cd rom enabled to boot the windows xp disc. After checking on the net i found something telling me to hit shift and f10 so i could set the pc to boot from the devices specified in the bios. So windows xp boots and starts to install i think everythings ok.
The installation just refuses to complete, It'll get to "installing devices" and take about a half hour to get through that, then it gets to "installing network" gets to the end of the progress bar and just sits there. I left the pc sitting for over 2 hours yesterday just to see if it would get past this and it just stayed on that part of the install. The little indicator blocks at the right of the screen are still in motion as are the messages of windows xp does this or that faster etc. It just refuses to go any further than this.
Ive tried different cpu's (two 2.8ghz p4's and a 3.2), different ram, different hard drive and still the same result, i formatted both hard drives probably 12+ times yesterday, set a new world record for times clearing the cmos in one day and this problem still persists. I was working at this pc for over 12 hours yesterday and can't figure out what the problem would be.
Tried calling abit tech support yesterday..predictably noone answered, tried today same thing, sent an email to abit tech support yesterday, same thing.
Took some pics of some of the settings, maybe someone can spot something wrong,
http://homepage.ntlworld.com/gerald.marley/pc/irq1.jpg
http://homepage.ntlworld.com/gerald.marley/pc/irq2.jpg
http://homepage.ntlworld.com/gerald.marley/pc/irq3.jpg
http://homepage.ntlworld.com/gerald.marley/pc/irq4.jpg
http://homepage.ntlworld.com/gerald.marley/pc/irq5.jpg
This is what i see just before the pc will boot from cd, doesn't look right to me
http://homepage.ntlworld.com/gerald.marley/pc/bootup.jpg
This is it trying to install windows, again stalls here takes half an hour to get through this and will just sit and do nothing when network is installing
http://homepage.ntlworld.com/gerald.marley/pc/winsetup.jpg
This is the shift+f10 bios screen for the lan settings,
http://homepage.ntlworld.com/gerald.marley/pc/network.jpg
Actually nothing in the manual about this at all so im not sure of the settings.
I tried reinstalling windows again and noted with my cable modem connected to the pc it displayed the realtek messgae maybe once then tried to boot from cd.
