Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Help i'm having trouble installing a usb2 card. Windows can't see it AT ALL. I think it may be because PnP is off but i don't want to change that BIOS setting unless i know for sure that XP is PnP. PLease help thanks!!!
When you say "can't see it at all" I am assuming that it doesn't even show up in the device manager?
I think that the difference between BIOS PnP is that with it off, the motherboard will attempt to assign resources as opposed to Windows assigning resources. This isn't always a good thing. If you turn it back on, theoretically, nothing much should change. Windows may reallocate some resources but it should be invisible to you.
If you are talking about the PnP service (in Windows; post didn't suggest it, but you never know), you need to have that on all the time.
yeah the damn thing doesnt show in device manager.
Its an adaptec 5100 BTW. So if i reboot, change the BIOS PnP setting, do you think that will help ease installation?
