Is this Power Supply enough.
TheEak
I overestimated my old power supply. Recently it died on me and I still don't know if all my components work.
I'm on a tight budget so I was looking at this
Rosewill "Stallion" 450w
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182075
Currently my setup is this:
Foxconn A7GM-S
AMD Athlon X2 6000+. Not OC'd
ASUS ATI Radeon HD 4850
2 IDE drives
1 DVD drive
The only thing I would plan on upgrading with this power supply is swapping out my old IDE drives for 1 SATA.
So what do you think?
No. Rosewill's PSUs are hit or miss, more often miss. You can tell that that particular model is an older design because it has a voltage selector switch, meaning it lacks APFC, so it is most likely not up to the task of handling a modern system, at least not with sufficient reliability. I suggest you go with this PSU instead: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
