I'm looking at buying a cheap NAS, but then I started thinking, and I'm wondering if this is possible. Instead of buying a single NAS, I could try combining two parts to create one, while keeping the versatility. If I took
This USB Male to 100BASE-T Female Adapter
And plugged it into this USB 2.0 enclosure
Would that allow me to turn the USB HDD enclosure into an NAS? If yes, would it support SAMBA and/or FTP? Forget that the two USB ends are not compatible, I could fix that with adapters, or choose another enclosure. It's just an example.
Thank you.
Thank you.
