m3ta1head
777
- Feb 22, 2006
A friend of mine thinks this socket is damaged-the 6 missing blocks in the middle. Can anyone confirm this, or is this normal?
The motherboard is a DP965LT.
Aye looks like its damaged, see this link on Intel's site, all contacts are intact
I completely agree that I think it's damaged, however that pic might be a different revision of the board. What's missing might be the equivalent of a capacitor that looks like it should be on the board but isn't or that is in one revision of the board and isn't in a later one. The only way you're going to know for sure is to put a CPU in and fire it up (unless you talk to an Intel employee who has more intimate knowledge about the board).
Strange. Just as I suspected. What would have caused a fault like this?![]()
If it is damaged the only thing I can think of that could have caused it would be carelessness or someone trying to mod it in a most rude way... Was this board purchased new or...?
No not broken !!!!
It's the two missing pin due to pin out and that Groove !!!
Gehhz go check all ur Mobos that are 775.
They all miss 2 pins near the Grove that makes the Chip fit only one way
No not broken !!!!
it looks to me like those solder points are clean and never used. I have an LGA board here that has open points in the socket area similar to the pic above and it works fine. Try the board... I'll bet it's meant to be that way.
Just out of curiosity, why would the Intel reference board have components soldered in there as the other picture notes?
It's not damaged. I am right. End of discution.
