So after much googling, I found this tigerdirect store and it has two mobo's that are socket 754 and have pci-e. My question is, is there a catch? I've heard there's a bridge that slows it down or something to that effect, just wanted to know what's up- are either or both of these fully pci-e compatible? I can't afford the migrate over to 939 right now, but I do want a next-gen card, so this is my option, which of these do you guys rec.? I see one of them has an agr slot, but it seems to work like dump. So i'm not worried about that, just want to know which one seems to have the best pci- solution. Thanks for the help
EDIT: My dumba$$ forgot the links...http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1284606&CatId=0 http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1366562&CatId=0
I'm leaning toward the MSI one, I haven't heard of this foxconn comp.
