is this everest readout normal (cpu underclocked?)
Layer01
I just got around to looking at my cpu temps with everest, here are my stats:
Gigabyte GA-P35-DQ6
Qx6700 (with stock fan)
8GB DDR2-800
8800GTX
2x150GB raptor
2x750GB seagate
But for the CPU it says:
QX6700, 2133MHz (8x267) <--when shouldn't it be 2667MHz with something like 10x267?
under the "overclock" section of everest it then says:
CPU clock 1600MHZ (original 2667MHz)
CPU multiplier 6x
CPU FSB 266.7MHz (original 266 MHz)
When i start something taxing, like a render using all 4 cores the CPU info in the "overclock" section will jump up to 2133Mhz and the multiplier will adjust correctly.
So i figured there must be some sort of smart voltage regulation going on..only it doesn't seem to be reaching its full potential of 2.66MHz :confused:
why would this be?
should i adjust the multiplier to bring it up to full speed? or is this not advised?
I get temps between 50C and 45C across the 4 cores on idle and from 55C to 60C on load
Use CPU-Z to see if it it concurs with Everest. Run Orthos instead of a rendering program while CPU-Z and Everest is running.
Yes, Intel Core 2 Duos/Quads have something called SpeedStep, which mean they downclock themselves when the CPU is idle or doing something not too intensive.
done.
PU-Z confirms everest with Orthos running
Go into your BIOs, and set the multiplier to 10. That should set things straight
Put that ~$1000 to good use and OC that thing. Otherwise, the Extreme edition chip was a waste of money. C'mon, even a modest OC will improve things. Keep voltage at or near stock if you want to preserve the life of the chip.
