is this considered stable for an OC?
y0!
x2 4400+ @ 262x9.5, 1.472v, RAM 2.5-3-3-8 2T (i think 5:4 for the divider) 3x HTT
okay: prime95 is apparently stable, i ran it for 10h33m on small FFTs and it only just fuxxed up, superpi has no qualms about it
but is it considered stable? i can't think of a situation in which my cores would be crunching something as heavy as mersenne prime numbers for 10h30m, games run fine and i have no freezies in any benchmarks of any sort
is it considered stable though?
Some people will say that if Prime95 ever fails there is a problem with stability...even if it is 3 days later. But it's probably stable enough for your needs. I've never seen any program put out as much CPU heat as Prime95 in small FFT's (even F@H running 100% is 3-5C cooler than Prime).
