I'm having an odd problem.
Recently I have had times where my system just shuts off in the middle of use as if it was suddenly unplugged. In addition, if I place the system in Standby mode and leave it alone for an extended period of time, the only way I can bring it back to life is to jiggle the power cord connection into the power supply. Neither hitting the keyboard or even pressing the power button on the front of the case will revive it. If I remove the power cord and then replace it, the system does not wake from standby, but instead reboots as if from scratch.
However, if I place it into standby and then try to revive it without leaving it alone for an extended period of time, just hitting the keyboard spacebar brings it out of standby.
I have replaced the power cord and confirmed that this is not a heat-related shutdown problem (my system is water-cooled and the CPU, an Athlon 64 X2 4800+ shows a temp around 38 deg celcius...)
Running XP SP2 with 2 gig ram.
The power supply is a PC Power & Cooling 510.
Any thoughts?
TIA!
Wazoo
Any thoughts?
TIA!
Wazoo
