Is this a Mobo problem?
j0nc12
About 3 months ago i setup a decent gaming rig from newegg.com everything was brand new nothing used 3 weeks into playing on my new rig i found out one of my sticks of ram was bad so i sent it back and got a replacement a week later my rig started getting more random errors after i just got the brand new replacement of corsair xms pro's here are my problems
1. computer restarts at random briefly giving me a blue screen that says something about hardware issue
2. after my pc restarts my pc says "windows has recoverd from a serious error"
3. this one is the most annoying anything i download that is compressed that involves unziping or extracting as soon as the extraction precetage reaches 99% it will say corrupt file on any file i have never been able once to extract any compressed file
to be sure this wasn't a virus i reformated my hardrive and still no success i even repalced my hardrive with another one and still nothing changed please help me i dont know what to do
My Rig
Athlon 64x2 4800+
Asus A8n32 SLI Deluxe
Ati X1800Xl
Corsair XMS 2GB (2 x 1GB) PC3200
Corsair 620w Psu
2 maxtor 400gb hardrives
do the rams mach (well not as they were twins, but in speed and timings), you could do a memtest
what do i need to do a mem test? i never played with my memory speed before i always left it as it is
http://www.memtest.org/
at bottom of web page
Download - Pre-Compiled package for Floppy (DOS - Win)
you will need a floopy, its a self extracting exe so hopefully you can get it to create the floopy.
Then set your computer to boot from floopy and let this thing run. It has its own mini operating system and is regarded as the best free memory tester out there. Takes a while to run a full pass.
Typically if you let it run overnite and get no errors you memory is regarded as ok and stable.
Here are some suggestions
I bet you then reinstalled your software applications and downloaded various utilities we all use. For example there is a copy of winzip floating around that has a trojan in it.
go here
http://www.clamwin.com/
and download the clamAV antivirus software and run it. its not like norton that screws up everything with your computer, it installs easy, and can be removed easy and runs only when you tell it too. Its very good antivirus software.
Do you have windows firewall turned on ?
What Operating system do you use ?
Do you overclock ?
What are your cpu temps during gaming, download from Asus, it might be on the cd that came with the computer, the utiilty for monitoring your temps and record what they are by alt-tabbing out of a game to get load temps, and what they are with the computer just sitting in windows.
I suspect a virus but any and all info could be helpfull.
let me first just say thanks bill for taking the time to help me and to answer your questions
i dont use winzip i use winrar
i do have windows firewall on
i use winxp pro sp2
i never overclock
i'll try to give you my cpu temp but i i dont have a program that tells me my temps
i really dont think this is a virus the first 2 minutes after i just freshly installed winxp i was just installing my video drivers ATI Catalyst control center and then my computer restarted 3 times in a row
Obvoiusly your Ram. Rma both sticks at once and get 2 matching sticks to replace with.
Here's my ram i'm sure there a matching pair
if it's my ram is that why i can't unrar any file
BIOS settings. Go in the BIOS and manually set EVERYTHING! Check the cpu clock speed, cpu multi, cpu voltage, memory voltage, memory timings, HTT, multi, ect. DOn;t leave anything on AUTO because it usually results in instabilities like this. I am willing to bet it is something with the memory (prolly not enough voltage).
