Highwind
- Sep 9, 2010
It's a doozy, and the cliffs are "I think it's the motherboard." You've been warned.
Corsair TX650W
Asus M3N-HT Deluxe
Phenom II X4 945 (C2 Stepping)
GSkill 2x2GB DDR2 1066 (F2-8500CL5D-4GBPI)
GTX 460 1GB (MSI N460GTX Hawk)
500GB Sata OS/Program Files (WD5000AAKS)
400GB Sata Storage (WD4000AAJS)
LiteOn IDE DVDRW (iHAP122 9)
Windows 7 Pro 64
1920x1080x32 (Samsung P2770FH)
For some weeks now now I have had frequent and sporadic issues with poor performance. The problem arose out of no discernible cause and is most evident during two activities:
1. Opening programs such as Outlook 2007, Steam, or just using browsing hard drives via Windows Explorer will cause the window of the program in question to open and sit non-responsive for several seconds. Additionally, when mousing over my Steam game list or the taskbar, highlights will lag behind the cursor substantially.
2. While playing 3D games, the framerate will plummet from the typical steady 30-60 (depending on the game) to 15 and under. While I have been using Fraps to confirm this, it is painfully evident even with no framerate counter. Looking at the ground or similar 'nothing' places have no effect on this anomaly.
Game examples include BFBC2, GTA4, The Witcher 2, Fallout 3/NV, HL2 and Source games, and even Halo 1.
Troubleshooting:
-I first suspected my previous GPU (GTX 260) was the cause, so I put in an RMA call and was pleasantly sent my current 460, but the symptoms persisted.
-Tested RAM via Memtest86+ v4.00 and Windows Memory Diag
-Moved page file to other drives
-Replaced my OS drive with one of the same model, reimaged, even reinstalled Windows
-Tested my rig with another ample power supply
-Tested with current (latest 3401) and previous two BIOS
Notes:
-Stock clocks or mild OC (CPU 3.3GHz, RAM 880, FSB 220, DRAM/FSB 2:1) make no difference.
-CPU, MCP, GPU, MB temps read well within safe ranges (each struggles to break 50 C under load) regardless of the above OC.
-The only component I've not been able to swap out with an equivalent to test is my CPU, but logging my CPU usage shows it is not fully loaded during this anomaly.
-MB has tall aftermarket chipset heatsinks.
I seem to have run a process of elimination that leaves the mainboard as the lone suspect. Getting a new MB is within my means, but it is a very low priority unless I am certain it will solve my problems and fulfill my hopes and dreams.
Questions/Comments/Input/Good morning
Corsair TX650W
Asus M3N-HT Deluxe
Windows 7 Pro 64
Troubleshooting:
Notes:
