Sorry, I'm not sure where to exactly put this thread - I hope people don't mind if this has a little of everything in it...
I'm thinking of buying parts and building in the next few days. I'd like to know two things:
1. Should I hold off for now (if there is going to be a dramatic price drop soon or new technology or something).
2. Are these good componenets and will they work together.
Case and power: COOLER MASTER Stacker 830 Evolution RC-830-KKR3-GP Black Aluminum ATX Full Tower Computer Case Real Power Pro 1000W Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119136
Motherboard: EVGA 122-CK-NF68-A1 LGA 775 NVIDIA nForce 680i SLI ATX Intel
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188013
Hard drive: Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
RAM: CORSAIR XMS2 4GB(2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail ( 2 of these, so 8GB )
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145176
Video card: EVGA 768-P2-N831-AR GeForce 8800GTX Superclocked 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130072
or,
EVGA 768-P2-N835-AR GeForce 8800GTX Superclocked 768MB 384-bit GDDR3 PCI Express x16 HDCP Ready SLI Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130079
Sound Card: Creative 70SB046A00000 7.1 Channels PCI Interface Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102005
CPU: maybe this one: Intel Core 2 Quad Q6700 Kentsfield 2.66GHz LGA 775 Processor Model BX80562Q6700
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115027
or this one:
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Processor -Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
Unfortunately this build comes out to around $2,466 according to my calculations, which is about $1,000 more than I would like to spend. I'm thinking of only getting the 4 gigs of RAM and dropping the sound card. Then I can buy the soundcard and another 4 gigs of RAM in another couple of months.
What do you think of this build, and is there a better one? I would like as many opinions as possible please
Again, sorry if this is cross-posting violation
or,
or this one:
