Is there any problem with my computer? Please help?
Anujith
I recently bought a new desktop. The specs are
intel core i5 2500k
corsair 8gb
asus 6950 2gb direct cu 2
asus p8p67
wd 1tb
cooler master haf 932
cooler master 700w psu
twinguard microtek 1kva ups
acer 20" led
One day i noticed some kind of black smoke coming from the front of my case, I shunt down the computer immediately then. I opened the case and check the inside of my case i didn't find anything wrong and i am not a pro.After some time I started the computer and nothing happened. Later i played crysis 2 for about 5 hours and nothing happened. The temperature of my gpu was 45c after playing crysis as showed by asus smartdoctor and idle temp of gpu is 37c. Idle temp of my cpu is 40c and of motherboard is 32c shown in asus ai suit. I am using the stoke cooler for mu processor. Yesterday i ran a torture test in prime95 (in blend mode) about 1-2 hours and noted my cpu temperature as 46c and motherboard temperature as 37c. Still no presence of black smoke again. The room temperature is about 22c in my house. Now please tell me is there any problem with my computer, i am a little worried. Also any useful information's and tips are welcome. Thank you.
This is just a wild guess, but did you maybe leave a sticker/some plastic on one of the parts? It mighta just burned up and that was that. Your temps all look fantastic though.
good csi on that one! I am very weary of that psu though I would keep an eye on it.
Is there a smell? If so, can you figure out where it's coming from?
You said it was BLACK smoke? That means plastic is burning somewhere, look around for a burn label or sticker. How long have you been using it before this happened, as in days since you aquired it? Did you build it yourself?
All you can do is keep using it, or take it apart and try to find scorch marks or soot from what ever was burning.
The monster on lost can sometimes appear as black smoke and then disappear. Be on the lookout for strange things happening around you, like trees getting uprooted or dead people visiting you or being thrown into a wall....
Yes i built it my self with the help of a pro. The black smoke came just hours after first use.
maybe you attached an incorrect usb header or audio header on the mobo?
Now there seems to be a new problem. When the computer is running in battery(ups) power there is strange buzzing sound coming from the case, I only noticed it now because the electricity was gone a few minutes before and the sound suddenly started. I am feel foolish because i never thought of checking it before. There is no sound when the computer is running normally.
