I'm currently using an HP LP2475 I bought 5 years ago. IPS panel, wide gamut, fair amount of input lag/blurring (but not too bad compared to its contemporaries). I was aiming for a compromise between image quality and gaming-focused smoothness/responsiveness. I should note I never did any kind of professional calibration, merely copied a list of settings I found online on tftcentral or some such.
This time around, I want to focus on factors that will maximize my gaming performance. Low input lag for better reactions, less blurring so I can aim while strafing, etc. It sounds like TN is the way to go. Furthermore, I've heard that 120 Hz makes a dramatic difference in fluidity. The VG248QE seems to get the gaming stuff right, at the expense of image quality. Here are some questions I've got:
1. Coming from an uncalibrated (ish?) LP2475 wide gamut display, how hard will it be to adapt to this monitor's image quality?
2. I've heard that PWM technology causes headaches in some people. How worried should I be about this?
3. Are there any other monitors that I should be looking at that deliver similar gaming results?
4. How much will buying calibration hardware improve the image quality of this monitor?
