albovin,
Let's agree to disagree on this. You seem to like a lot the NEC LCD2490WUXi, which is IPS. I'm not familiar with this monitor, and maybe it is indeed great and doesn't suffer from the grainy look and glow of most IPS panels. However, I can tell you that at 30", the best monitors are PVA and not IPS. I have tested 30" monitors extensively (both PVA and IPS), and the best ones right now are PVA. If all you care about is gamma shift, it's one thing. But if you're looking for the best overall 30" monitors at this time, they are PVA, not IPS. The Eizo CG301W is better than the NEC LCD3090WQXi, and the Samsung 305T is better than the Dell, Apple, HP, etc. 30" IPS monitors. This is based on extensive personal experience with all these monitors. Again, there's less gamma shift on the IPS monitors, but the PVA monitors win on many other fronts (less grainy look, better contrast, less heat, less backlight bleeding, no glow).
