Is response time relative to input lag?
This might be a dumb question, but I see people with the NEC 2690WUXi which has a 16ms response time say that there is no perceivable input lag.
On the other hand, the Samsung 275t is 6ms, yet people say that the input lag is pretty bad. I'm just a little confused here. Anybody here care to enlighten me?
Not remotely, Input lag is related to the scalar in the that the OEM puts on the panel while response time is how long the panel takes to change from one color to another. You get input lag when the scalar has to do stuff (color, other inputs, non-native res, etc) while you get ghosting when the panel can change the pixel's color fast enough to keep up with the image.
Not remotely, Input lag is related to the scalar in that the OEM puts on the panel while response time is how long the panel takes to change from one color to another. You get input lag when the scalar has to do stuff (color, other inputs, non-native res, etc) while you get ghosting when the panel can"t change the pixel's color fast enough to keep up with the image.
What he said. Plus, there is no real hard spec on how these manufacturers rate responce times. Some manufacturers even rate differently for thier own differing product lines.
Very few modern LCD's ghost badly. A few years back that was not true.
Imput lag can really alter how you play games. The bad ones will make you want to give up gaming. The good ones have no perceivable imput lag, or only barley perceivable amount of imput lag compared to a crt.
Response time is the time measured for the pixels to display a certain color while already in a particular state. Most of the time this will be G2G (Gray to Gray), meaning the time it takes a pixel to display a light gray then change to a dark gray (much easier than black to white or even gray to white or black). Ideal for marketing, the majority of listed response times are now G2G. On older displays, or displays marketed to professionals, the response times are more acurate, and a decent measure of the "ghosting" one may encounter with that display.
Input lag is the time it takes for the signal coming from the video card to reach the pixels and display that image. There are other factors involved in input lag other than just the monitors software and hardware, such as your mouse and the rest of the parts involved in getting the input processed and to the monitor.
Thanks of the clarification guys. So basically, there's really no way to tell if a newly released monitor has low or high amount of input lag without buying it and testing it out yourself?
some sites like digitalversus test for input lag and post the results in their reviews but they might not have the lcds you are looking at because it is a french site so they have some different models over there but it has ones like the Samsung 2232BW.
Hey there,
As J0J081 mentioned, Digital Versus is a good research tool.
In fact, in some cases, response time and input lag are mutually reversed. Ie. some manufacturers use overdrive to improve response time on panels (such as MVA based monitors) that causes extra image buffering and increases input lag.
The concept works like this: Image 1 has an image that is on the left side of the screen, and image 2 has the image closer to the centre, so the image is moving left to right. When overdrive is used, both image 1 and 2 are buffered, and a different voltage is calculated and applied to the target pixels to "overdrive" the pixels to improve response and speed in which they display that moving image/game character/etc..
All this extra buffering increases input lag because of the extra image processing, so one could say that in some cases, the image processing causes lag.
This is why you will see 2ms vs. 5 or 6ms, or even 12ms panels that have higher input lag.
As far as the LCD2690WuXi is concerned, this monitor performs more image processing than most, so the slight input lag (which I can feel to a very very small amount) is expected. It also has one of the most advanced scalers in consumer level monitors, which may also attribute to slight input lag.
Generally you will see the highest input lag on PVA based monitors that are using Samsung panels (at least recently).
Regards,
10e
