GNUse_the_force
- Oct 27, 2014
Discuss.
You first.
There were great 120hz TN monitors in 2012, namely 3d glossy samsungs: 750d and 950d.
These actually looked better than any entry level matte IPS, while having accurate enough colors.
Unfortunately no one cares about picture quality in gaming monitors anymore, see: 1k$ asus swift with a horrible 3h matte coating.
Well, at least TV's are progressing today, you would be hard pressed to find a non glossy, non VA TV in stores.
Those had some serious backlight bleed/uniformity issues
anything else worth replacing it with besides the ROG swift
Those had some serious backlight bleed/uniformity issues, and some other bugs. I can't recall exactly what the problems were, but there's probably a good reason why I don't have one of those monitors right now. I really, really wanted one of them at the time (primarily for the glossy screen), but in the end I decided it wasn't worth the risk for whatever reason.
VA panels are significantly better and cheaper.
Producers are servants for consumers which decided monitors must be cheap and good enough, and so they are. Good enough for Joe Sixpack is barely acceptable or below standard for Jim Sophisticated.
I take this to mean "better than other VA panels in the past." If so, which ones?
There are plenty of good 1080p VA panels available for less than 300$ which are not wide gamut unlike the majority of S-PVA panels, have higher contrast, far less ghosting, lower input lag, lighter coatings, and better colour presets.
Appreciate your reply but it's unspecific. Name three examples of what you claim and I'll research it and tell you whether I think they live up to, say, the Samsung 244t.
Upgrade to highend tvs. Day and night when compared to the same ol monitors.
http://hardforum.com/showthread.php?t=1803228&highlight=
Asus VN279Q, BenQ EW2740L, BenQ VW2430WH, Iiyama X2483HSU, iiyama XB2783HSU, Samsung S2xC750P (review links are available in the thread above).
The biggest problem with screen quality is LED backlights, I have a CCFL IPS screen here and it has 0 backlight bleed, 0 uniformity problems and 0 IPS glow. Unfortunately its 20".
I owned plenty of CCFL LCD screens and many of them had uniformity issues so I don't believe you are correct. Its all a lottery. Most panels are just put together on a fast moving line and there is no time to check each one for such things otherwise the cost would be higher.
The truth is the desire of manufacturers to make the cheapest panels is often the reason why we are dealing STILL with uniformity issues years on from CRT's.
You can pay for a cherry picked panel without such issues but you'll pay quite a premium.
TV panels are getting all the upgrades (minus G-sync) and in general are of better quality. Like it or not enthusiasts like us are a very small minority for PC monitor manufacturers. Making a monitor with our demands in mind just isn't profitable enough for them. We've had maybe two truly gaming centered monitors that were a step forward in recent memory? (Foris and the ROG) Both plagued by defects and panel lottery bullshit.
As of right now PC monitors seem to have almost stalled. Better in some respects , yes , but worse in many others.
I really don't understand how we're a small minority and it's not profitable yet they can't even keep the ROG Swift in stock. There is a HUGE market for a quality gaming monitor. It's simply that nobody's delivering. It's pure idiocy on their end.
