Is my rig still OK?
horrorshow
Lakewood Original
I'm hoping to get through the next 12 months or so with the box in my sig....
Does that sound feasible?
Besides already playing Fallout 3, the only new games I'm looking forward to are Left 4 Dead and Starcraft 2. (I would list Diablo 3 but we all know that's a wayyyyyyys off)
Anyways, input is appreciated as always.
Thanks fellas.
Getting a newer video card, like the HD4850, would enable you to play some of the newer games that are (coming) out. But if you're satisfied with the performance you're currently getting, then you could stick with what you have already.
How much, at most, would you be willing to spend on upgrades to this rig?
It's feasible. Whether or not a system will last long is totally up to you. If you're gonna demand/want medium to high settings with 60+FPS, then no that system will not last long for your tastes. But if you're fine with the current performance and are not a very demanding gamer, then yes that system will last a while.
Sadly, I'm part of the AGP Club and the 3850 is THE most powerful video card available.
I just upgraded to that from a x1950 Pro and added another 2 gigs of RAM.
I seriously don't see upgrading this box in any form or fashion....
Hence my main question, "Will this rig last me another year". Because after that, I intend to do a complete rebuild.
Can you play Fallout 3 well (to your satisfaction)? Are you willing to play Left 4 Dead at low or medium-low visual settings?
If the answer to both of those questions is yes, then it will last another year. I can't give you a definite answer because I don't know what your standards are regarding gameplay.
I don't think he will need to play L4D at low settings... I have the HIS 3850 and I am bottlenecked by my single-core processor and I can play all other source game at max settings at 1440x900 with no problems. We all know that source likes processors best so the only thing I would recommend is to max out the processor on that board...AMD's are cheap as hell right now and it will only unlock more of your video cards performance. I mean you can get a 6000+ for what? $85?
He has a Socket 939 mobo so, there's not much X2 Dual Core cpu options he can upgrade to. An X2 6000+ cpu is a Socket AM2 (940 pin) cpu. You have choke RAM though for WinXP though hehe.
horrorshow, the OP, has a Socket 939 processor and motherboard and an AGP video card. And he just recently upgraded said video card.
In other words, he's pretty much limited in what he could do.
My only concern (now) is with the power supply. If you plan on keeping your system as long as possible (even after your upgrade), I recommend getting a cheap yet effective power supply like the Antec Earthwatts EA500. The Antec TruePower/SmartPower PSUs have had a history of failing at random times... though Antec has since fixed that problem with its current line of power supplies.
You will be fine if your willing to have lowered settings. The real way to tell if your machine is "OK", is if you have to lower settings below what your happy with. As long as the games you have are playing fine at settings that you are happy with, then your machine is good enough.
you'll be fine, you don't sound like an fps hog, the games will run smoothly, you won't have sun rays, life like smoke, perfect shadows or cool water, but most people can live with that.
By most people i mean everyone not on this forum.
PS wrong place to place a build like that and then say you can't upgrade it, some of us will have nightmares tonight
That was... a bad plan. Should've at least picked up a PCIe S939 board. There's plenty out there used for $50-60, and 4GB of DDR2-800 runs $50-60 shipped anymore. Then you would've had far better GPU options.
i think your rig is still not bad at all, but i would save up money to build a new rig :D But i wouldn't mind playing games on that specification at all!
From what I've seen, the only thing that will hold you back is the processor and video card. I think that by doing some minimum upgrades, like a cheap video card and and better dual core processor, you should be alright for another year. I have a similar card, and it has never failed me, even keeping up with crysis at 30fps.
