is my rig even worth upgrading?
my rig:
p4 single core @ 2.6ghz (socket 478)
1gb ddr400
256mb radeon x700 pro agp
its pretty obvious that i wont be able to play any new games coming out (my vid card is actually BELOW the minimum requirement for bioshock :eek: :(), but my dilemma is whether its even worth it to dump more money on this rig. i really want to play bioshock and maybe some dx9 crysis when the time comes, but i keep thinking that i would ultimately be better off waiting until i have the money for a brand new dx10 system. if i were to upgrade, that would mean another gig of ram, an x1950 and a 3ghz single core p4, which would cost somewhere around $300. would i see enough of a performance gain to justify the purchase, or would i really be better off saving up?
If you decide to upgrade, I don't think the difference between a 2.6 and 3.0GHz is worth the money. I'd spend that money on another gb of RAM. The x1950 I agree with.
Maybe an Asrock 4Core Vsta mobo ($65), a dualcore e2140 or e2160 cpu ($75 /98) or e4400.
The Asrock 4Core has both AGP & PCI-E video slots, and DDR & DDR2 ram slots. You can't use both type of ram at the same time. You can use both AGP & PCI-E slots at the same time (no SLI), though the PCI-E is limited to 4 lanes (which probably takes 10 - 15% off max fps). Overclocks look like they're limited to about 300 fsb, so cpus with a high multi would be best
Don't upgrade at all. After the GeForce 9800 comes out all the 8000 series will cost you what you would pay for a 7000 series gpus, they will be so cheap and you'll get your directx10, omg.
I'm not going to tell you what to do... but I will offer a comparison..
I currently have a P4 3g, 2g generic ram and an X1950pro AGP.... and it plays most games acceptably... not maxed out, but it's playable...
Good luck with your decisions:)
have u tried bioshock on it yet?
hmm.... my suggestion is to upgrade this year to C2D system. these C2D cpu is insanely overclockable and very good.
no, don't upgrade at all. 2010, intel will release a 32 core processor. dumb move to upgrade ever. :D
In all reality, I'd say save up 800 dollars and upgrade.
I say save up more money. Don't bother with any more upgrades to that old PC.
