After 18 months of being absolutely fine, I've been having increasing trouble with my PC not waking from sleep or getting it to even POST (let alone boot!) from shut down.
When it doesn't POST like this, my gfx card (Radeon 4870) gives three solid red lights (D1601-3, much like this guy: http://hardforum.com/showthread.php?p=1034365010), so I figured it was the gfx card and bought a Radeon 5770.
However, the PC still fails to POST! I've tried unplugging 2 unnecessary SATA drives (blu ray and USB extension), I cleared the CMOS and swapped out RAM, but still doesn't POST! Now I've ruled the gfx card out (ruling out the new 5770 being DOA as that would be terrible luck!), could it be the PSU? Various threads on the 4870 three red light issue suggest the gfx card may be lacking power?
Any help would be most appreciated, I'm going crazy and can't afford to keep getting new components!
Thanks in advance for any help, spec below in case that helps!
OS
Vista 64-bit
Processor
Intel® Core2 Quad Q9450 (4 X 2.66GHz)
Mobo
ASUS® P5Q: DDR2, SATAII, PCI-e x16
RAM
8GB CORSAIR XMS2 800MHz (4x2GB)
Graphics Card
512MB RADEON HD 4870 PCI-e
PSU
FSP700 700W Quiet Quad Rail PSU w/ active PFC
- Now, if I try to wake up the PC from sleep within 2 minutes of putting it to sleep, it will fail to wake properly 100% of the time (lights, fans etc come back on, but no signal to monitor or AFAIK any processes running etc).
- If I try to boot the PC after shutting it down, it will fail to POST most of the time. No POST beep is made, nor any error beeps. At no point does the monitor receive signal, but all the fans seem to start. Once this happens, it won't POST at all until it's "rested" for a few hours!
OS
Vista 64-bit
Processor
Mobo
RAM
Graphics Card
PSU
