Is my mobo dying?
Modred189
Can't Read the OP
Patient: P5B Deluxe, WIFI/AP
Age: 2.5 years
History: No previous symptoms or issues
Symptoms: If you plug ANY kind of USB device into the case's (Antec 900) front headers, any USB device plugged into the mobo, front or back is dropped. USB devices plugged into my 4-port USB PCI card are fine.
Case History: I switched which header the front ports were plugged into on the mobo, no change.
Thought of using the PCI card for all USB devices, but the I cannot access the BIOS.
It's annoying to have to reach back to my HUB to plug in a USB memory stick.
Ok, [H]ouse, what's your diagnosis, prgnosis and treatment plan?
i would try changing which header they are plugged into on the motherboard for the fronts.. but if the back ones are working.. id probably say it might be the front plugs on the case that are the problem..
As I mentioned, I did change the header, same thing. It does affect the rear motherboard USB ports, but not the usb ports on the PCI card.
The USB ports on the PCI card are being fed by the PCI slot. That probably isolates them electrically from the regular USB circuit.
I'm voting with Sirmonkey that the case plugs are a problem.
I tend to agree re: the case plugs. But why would they kill the devices plugged into the back of the mobo? Short?
My thinking is that all of the MB's USB ports have at least one common connection, either power, ground or both.
I'm thinking the case's front USB plugs are grounding to the case.
Woah, I was just having something like this today. For the life of me, I can't figure it out.
My USB ports seemed to have failed... I cancelled a windows update ( that might have done it ) but I've tried pretty much everything to get it working, but alas, after a night's worth of sleep time, I still have it failing.
I'm thinking it died, or rather, dying.
its mostly likely a prob with the front ports but try disableing your usb port then bring them back with older drivers and c what happens
