D
Deleted member 85430
Guest
I've got a 4570s with 16gb ddr3 1600.
They're full of it, no, the CPU will not be a significant bottleneck.
https://www.hardocp.com/article/2017/01/13/kaby_lake_7700k_vs_sandy_bridge_2600k_ipc_review/
GTAV said:
are you kind of retarded to not know the difference between a quad core/eight thread 4.5ghz CPU versus a quad core/ four threads 3.0ghz (max turbo on 4 core load when stressed) CPU? the shit will perform even worse than a 2500K at stock settings which turbo to 3.5ghz on all core at stock.
you want to see how it perform with a Titan X (slower than the GTX 1080 by a good margin)
isn't the video enough?
oh wait.. an extra it even bottleneck at 1440P in GPU bound games:
Just imagine what it can cause in heavy CPU intensive games, as Watch dogs 2, Mass Effect Andromeda, Fallout 4, Battlefield tittles, etc etc..? lol. next time stop embarrassing yourself and stop misinforming users..
i5 4570S it's far away of being anything close to be a good gaming CPU first it's locked, and second it's designed to run at LOW power. so it tend to just run at 3ghz - 3.2ghz if you are lucky when all cores are under load.
Do you already own the 1080?ok. my day is ruined. thanks guys.
What are you trying to play? You could always buy the 1080 and upgrade your CPU later. You'll still be able to play games with it just will be running at probably 60-70% it's potential.
.... Look at the numbers you're actually quoting.
An i5 3470 is less than 10% lower FPS than a 5960X. A 2500 is a whopping 15% slower than a 5960X.
I'll bet his CPU will do just fine with a 1080.
Would a faster CPU run it better? Of freaking course it would!
But his CPU won't stick him at 25FPS or something terrible, it's still going to be very capable and run decent FPS still.
Assuming you're at 1920x1080 it will be a 'bottleneck' in the sense that you may not get the full expected performance. However you will still get great framerates overall and surely a boosted experience over whatever you have now presumably it's mid-tier from that generation (same as CPU).
If you're at 1440p or higher it will be even less of an issue.
I would consider, however, looking at trying to source perhaps a cheap used 4790k and drop it in?
Alternatively consider the GTX 1070 Ti as well.
If you're on a 4K TV: 1080 upscales to 4K better than 1440.i'd like to run 2560x1440 and let my tv upscale to 4k. i usually play: watchdogs 2, gta5, skyrim modded, fallout 4, prey, bf1, bf4, infinite warefare, cod4 remastered etc...
A 4570s is only a hair faster than a stock 2500k so not too terrible and should still be ok for keeping 60 fps in most games but dont expect that in every title. I guarantee you that it will be fully pegged in many newer games and you will see some stutter and hitching in a game like Mafia 3 for sure.
And why is this about the 4570s when there is a 4790k in your sig?
i have a 4790k in one of my machines that i use for video editing and davinci. i can't touch it. - in my sig.
the card i have now is a RX 570 MSI gaming.
On your current RX 570 and that CPU, turn your resolution down to 720p or something and turn all settings to low/medium. Game on that and see if you are fine with your FPS (especially the minimums). If you are happy with the FPS then buy the 1080 and enjoy pretty much the same experience but running at native resolution with all settings high/maxed.
Edit: just realized I said the same thing as bob above XD
So because you have low standards and or are quite oblivious then that makes other people insane? You claiming "no issues" does not change the fact about that CPU being a limitation in many games and even some stutter in a few titles.I run an i5 2400 CPU w/ 1080 GTX on a 4K TV. No issues. These people are insane.
So because you have low standards and or are quite oblivious then that makes other people insane? You claiming "no issues" does not change the fact about that CPU being a limitation in some games and some stutter in a few titles.
And no one is denying that as far as I can see. The main point being made is that that CPU will be holding back some games from even maintaining 60fps and he is going to get some stutter in some games too.The fact that him upgrading to a 1080 over his current RX 580 will give him a performance boost beyond what any CPU upgrade will give him is what makes you people insane.
He will be able to play all those games BETTER than his current GPU, by a good margin.
I run at 320x200, but they are artisanal handcrafted pixels.
ummm ...... [H]ard Forum ?Jebus, you guys can be really brutal.
are you kind of retarded to not know the difference.....
