Is my 550 enough? Plus a mushkin question
BronxBartoni
So, i picked up 2 96gt's on sale for 120 a piece last week from worst buy, and everything is running good. But I also have a 500GB HD comin in on friday, will my TPII550 be enough for my quad (which is undervolted @2.7) , 2 dvd drives, the two 96's and 3 sata HD's? I plan on getting a new PSU next week, this mushkin 800 watter. Will my current PSU hold up for that long?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817812006
Thanks guys
Thanks for the replies guys, good to know my current will last a lil bit. I will prolly dial down the OC just for goodness' sake, until I get a new one in. Any reason other than that theres no reviews for the mushkin? I might pick her up jsut to try it, could always ship it back to newegg. And I would rather not get a BFG product, had a bad experience with them in the 6 series days.
Mushkin doesn't have a proven track record of good PSUs. Don't risk the potential safety of your PC with a PSU of unknown quality like the Mushkin. That particularly Mushkin is Topower made so it can range from all right to good. Still though, there are a ton of cheaper but better quality and well known PSUs like the BFG I mentioned.
Other PSUs to check out:
Corsair 750TX 750W PSU - $115
PC Power&Cooling S75QB 750W PSU - $130
Thanks guys
Did you mean under volted at 1.7 (I hope);)
