Is it worth another $100 for a E6600?
So its like $100 to go from the E6400 to the E6600...only 265 mhz or so different clock speed...I've never overclocked anything before and am kind of afraid the chip will fry the second I bump the speeds up a notch :eek:
IMHO no.
But I have to ask what are you doing with your computer?
And what are the specs of the rest of your machine?
And how long do you prefer to go between upgrade cycles?
Here is some info on how much and with what the larger cache will impact you, and perhaps if you can find other opinions they also should be considered.
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2795&p=4
If you are a gamer I would put the extra cash in the video card. If budget is not a concern, go for it.
Both chips will overclock easily, would be a shame not to take some advantage of it, even with stock heatsink you can easily get 2.8 GHz out of either chip.
Sound advice on the video card.
Don't be too afraid to overclock, just get a huge honking air cooler and crank it up carefully, you won't fry anything if you are careful.
An E6400 overclocked to 3200 is pretty potent and a good value.
Thanks for the help!
I think I'm going to go ahead and go with the 6600.
I keep hearing talk about a price drop...is this going to be within the next month or two? If its not going to be until next quarter I think I'm going to go ahead and just buy now...
Also on a sidenote here is another question. I've heard people saying the 4th timing on sticks of memory doesn't matter with the E6x intel chips. Is this true...? If so I won't spend more to get a 4-4-4-5 and will just stick with a 4-4-4-15 or something
The E6600 will be only $215 in 2 months, if you cant wait, hold off a little.
Honestly, I'm a loser and can't justify saving $75 by waiting 2 months, even though I probably SHOULD wait (financially speaking) :(
or :)
Yes, it's true. That 4th timing (tRas) doesn't do squat in terms of speed. I tested it out myself. I went from 1 - 15 and there was no difference.
