Is chrome compatible with windows 7 yet?
& running 3.5.6 without any issues on w7 64 bit for awhile.
For the last year, FF has given me so much shit, it started after an update awhile back.
First issue:
After browsing for an hour, FF would hog a ton of resources
2nd:
Flash freezing, doesn't happen on IE, hmmm?
3rd: Would max out my internet connection, only way to stop it was to block firefox via firewall, then restart.
4th:
I used to love it, but damn, it can be a piece of shit!
1) Out of curiosity, what are you calling a "ton" of resources?
2) Flash uses a different plugin in IE than it does for everything else. Thus, testing Flash in IE doesn't tell you whether its the browser or not. Make sure you've updated Flash for other browsers!
3) Sounds like you have a malicious or corrupted addon or install. I'd recommend uninstalling it and reinstalling it. :/
Flash sucks
Firefox uses too much memory and also tends to be more CPU intensive. I used to use Firefox but now I have switched to IE. I found IE to be excellent at memory management and the CPU utilization while playing flash is the lowest among all other browsers
Chrome plus the extensions is also an excellent choice. I still prefer IE, but Chrome is good
Fixed that for you
No, but seriously, its the flash PLUGIN that sucks, not Firefox. Firefox doesn't magically make flash suck more. Use flash in Chrome and you'll see the same crappy behavior (even worse in Chrome as Chrome crashes far more often than Firefox)
If anything I give chrome is that it just allows flash to crash instead of trying to keep it going like IE and FF does, this is also why it seems like it uses less memory.
Get Chrome or Go Home
