Is it the CPU or mobo???
Crowsnose
I've been having a lot of problems with my rig within the last 6 months or so.
Antec 500w PSU
Asus P5B-e
C2D e6300
2gb ddr667 ram
8800gt 512mb
160gb seagate
The main issue is with the start up. First off it's nearly impossible to turn on. The power button does nothing, the green LED on the mobo is lit and from tests I've done the PSU is fine. When I can eventually get it to turn on I'll usually run into 2 problems.
Problem #1:
BIOS message that says "Overclocking failed!" I've heard this is a common problem with this mobo and this occurs even when I'm not overclocking. The most overclocking I've ever done is about 20-25% 266x7 -> 333x7 for no more than a week. My vcore was underclocked, my cpu temps were good... I was careful not to do anything to ruin the chip so I hope that's not the problem.
Problem #2:
After the initial BIOS screen I get a message that says "NTLDR missing, press ctrl + del to restart" or "Insert proper boot device then restart." I can usually get past this by rebooting a couple times but I really have no idea what's causing it. I know NTLDR has to do with the harddrive but I doubt that's the problem, it's done fine under hdd monitoring software and my connections are secure.
So bottom line, do you think the underlying issue here is the e6300 which has been modestly overclocked for short periods of time since I've had this rig (2 years) or the p5b-e motherboard?
Processors rarely fail and almost never fail partially. If it works at all it's probably not the processor unless it's undercooled. Probably the northbridge chipset cooling or low voltage from the PSU or voltage regulators.
Yea, I mean, when I am able to get it to turn on properly it runs beautifully. Everything seems fine and all is well up until the point I decide to shut it down again. I was paranoid about it so I'd usually leave it on for days at a time. And though I dismissed it earlier, if the PSU were to blame would the system be able to run that stable when left on for days at a time?
Sounds like a motherboard issue. You'd only get the NTLDR message if something is screwed up in your bios with boot devices. e.g. it can't find the operating system. Might also be a bad cable.
easy, clear the CMOS.. take the battery out for 2 mins, then put back in and everything will be 100%
Problem #1:
your underclocked Vcore may not be supplying enough voltage to your cpu to function properly even when your cpu runs at default speed. try bump the Vcore back to the value recommended for your cpu.
Problem #2:
NTLDR is a windows bootstrap loader. Do you have more than one partition on your disk? or more than one disk? when it shows "NTLDR missing", it means the motherboard is trying to boot from the wrong partition (which does not have a OS installed). try setting boot device priority in your bios to the correct drive.
