Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I would think so...however it would help if you put ur system specs in a post or something also if you havent already check out the D3 hardware guide that should be able to easily answer your question and if not then skim through the D3 hardware guide thread at the top. There were a lot of "will my system run with these specs?" posted in there with a lot of positive responses to them
probly will run, definately not at those same settings.
D3 is a bit more demanding then far cry
What VidCard you running?
if you say GF2 you deserve to be bitch slapped j/k
