Is it even possible this could be a short problem?
zrikz
So I bought a new Asus M2N Sli Delux motherboard a few weeks back and have been having tons of trouble, and even more trouble with asus tech support. Long story short they say I have a bad bios chip, got the new one today and put it in and still have the same problem. The problem is this: The computer powers on and then turns itself off after around 3-5 seconds.
Called tech support again and they say I have a short, while I thought so also... I have tried putting the motherboard on cardboard, on my counter top not touching anything with the same effect.
The Solution: The only way I can get it to turn on is if I pop the bios battery and then put it back in.
So even if it was shorting, clearing the cmos would in no way solve a short problem and I finally convenced the tech support guy too I guess. Apparently Im going to have to RMA the motherboard through Zipzoomfly, but being without a mobo for 7-10 days is some BS... anyone have experience with getting a swap some how? And of course my 30 day purchase date ends July 5th so Im going to have to some how get this solved on monday and ship it monday morning / order a new one I have no idea... im unhappy.
Quicker than RMA to manufacturer is sending it back to retailer and seeing if they'll swap it out for a new one.
why do you think it will take only 7 to 10 days? it will take 2 or 3 days to reach where ever, it will lay around in the mailroom a day or 2 (the bigger the retailer/manufacturer, the longer it will lay around), then it will be "tested" for a while, sent back to mailroom to wait around some more, then you will usually get ups ground (7 day) shipping in return. good luck.
im not sure if you can do it through zzf (i know you can with newegg as long it is within a certain time period), but if you can rma it for a refund then just buy another one from zzf with free two day shipping
Thats what i figured I would have to do.. that sucks maybe I will try and order one tomorrow and have it here by monday and then ship out my other one monday morning.
An update because I feel like sharing my joyfullness. I ordered my new motherboard and it got here today, I installed it and I get the exact same problem: Computer turns on for 5-7 seconds then shuts itself off. I can get it turn on only if I reset the cmos every single time I turn it off. so I call asus & antec, they then say well maybe its a power supply problem.. I decided to agree with them considering I have gotten new ram, mobo and tested the gfx card at a friends so all that leaves really is the psu.
Background: I bought my power supply at newegg back on 5/22 so I was quite a bit out of my return period, but figured hey might as well try. Long story short, newegg hooked me up with a overnight delivery of a new power supply with free delivery and gave me 5$ credit on my card to return the dead one. Even if this doesnt fix everything I am still amazed at neweggs customer service. Dianne S. the customer service rep just made my week.
just a thought, do you have the mobo standoffs installed in the case so the mobo doesnt short out from touching the metal mobo tray?
Have you tried running the motherboard without your case's power switch? Typically, if the power switch is held in the "on" position too long, it will shut down after 3-5 (actually 4) seconds. A bum power switch sounds like the problem to me, although that doesn't exactly answer all the questions, but it's a place to start looking. If you've never done it before, just short the two jumpers that are the "power switch" on your computer with a paperclip or something, and see if it will stay running.
To both posts above, I have tried shorting it with a screw driver and have had the same results. I have also had it sit on a cardboard box and on my counter top with the same result also. If it ends up not being the psu.. I am at a complete loss and might have to try and take it somewhere to be looked at I guess.
