Is it not 05 reallocated sector count? One is 100 and one is 253, i have more disks i just showed 2 here.
http://crystalmark.info/software/CrystalDiskInfo/manual-en/SmartInfo.htmlCount of reallocated sectors. When the hard drive finds a read/write/verification error, it marks that sector as "reallocated" and transfers data to a special reserved area (spare area). This process is also known as remapping, and reallocated sectors are called "remaps". The raw value normally represents a count of the bad sectors that have been found and remapped. Thus, the higher the attribute value, the more sectors the drive has had to reallocate. This allows a drive with bad sectors to continue operation, however, a drive which has had any reallocations at all is significantly more likely fail in the near future.[12] While primarily used as a metric of the life-expectancy of the drive, this number also affects performance. As the count of reallocated sectors increases, the read/write speed tends to become worse because the drive head is forced to seek to the reserved area whenever a remap is accessed. A workaround which will preserve drive speed at the expense of capacity is to create a disk partition over the region which contains remaps and instruct the operating system to not use that partition.
One is 1 which I wouldn't worry about and the other is 38 (which I would worry about if it starts getting higher at a normal pace).
I agree. I use nagios to monitor the SMART (among other network params) for over 100 disks at work. I have seen drives stuck at 50 bad sectors for 2+ years and others go from 14 bad sectors to over 2000 in two weeks. The drive with 50 bad sectors still is being used. However I tested and RMA'd the 2000+ bad sector drive. I place the growth of bad sectors to be an important factor.
Can you monitor SMART on disks that are on a RAID controller with that?
Thank you.
That was the answer i was looking for. From now on i will only look at the raw value. The Raw value is the same for every manufacture right?.
Nagios seems like an enterprise solution, overkill for one or two PC's?
