Is 430W PSU enough for these...
Cannibal Corpse
- (X3) 7200RPM Maxtor Hdd's
- (X2) DVD -/+RW IDE
- ATi RADEON 9800XT
- Sound Blaster Audigy 2 Platinum (with IO Panel)
- Floppy Drive
- ATA 100/133 IDE Card (PCI)
The reason I am asking is because the image on my primary monitor, (the START button area) "throbs" (sometimes, not always)
Could it be because my 9800XT does not get enough juice?
Your comments and insights are greatly appreciated.
Not all power supplies are created equal, but 430W should generally be plenty for that setup. You could try a different power supply or unplugging a few of those HDs/DVD-Rs to confirm that.
It sounds like most likely a monitor issue or something creating interference. Have you tried moving everything that could possibly cause interference far away from the monitor? You could also try switching resolutions/refresh rates.
If its a name brand power supply such as Antec True, Enermax, etc., then yes that is plenty enough, if its not name brand then I don't know.
If it's brand name then no problem at all. 430 is PLENTY for that.
Do you have a speaker placed close to the monitor? The magnets, if large enough could cause something like that to happen.
ThE s[H]aDoW
Yes indeed it is an ANTEC brand. I am going to see if running 9800XT off of a dedicated power (rather than a shared) would make a difference.
On my Antec True 430w I run 2 HD's, Tv Card, 9800 Pro, DVD, CDRW, and have no problems. The Antec's are great PSU!
Very few people on this entire forum have a uniprocessor system big enough to need more then a 430w PSU. Its all about knowing how to divide up your hardware. If you daisy chain too much stuff off one line you'll cause problems. I difinitely would not have my video card on the same line as those hard drives.
If it makes a difference, I'll renounce my non-existant religion and find Christ. :rolleyes: When you go to switch to a "dedicated line", ask yourself how PSUs are constructed... All wires of the same voltage come from a common point in the PSU. So it *shouldn't* matter. That said, however, I've heard of people fixing stability problems by doing that, because hypothetically there can be a slight voltage drop when you have other devices attached. YMMV
Also, if you have too many devices on one chain for the physical wire to handle, you'll have problems, but the likelihood that you've pulled that off with that system is slim to none. Antec puts good, high gauge wire on their supplies, so you'd have to draw upwards of 15A over one wire to have any problems.
Hey now, lets not go dragging Jesus into this. He didn't do nothin to deserve to be caught up in a PSU thread lol :p.
Overloading Cables
The main thing to look for when buying a power supply unit is high power and low operating noise. But a look at the equipment is important, too. Crucial features are not only the number of connectors for 5.25- and 3.5-inch devices, but also the length and number of strands in the cable.
The number of HDD and FDD connectors and their distribution on the cable strands must also be considered. At high power levels it is important to distribute the load among several strands, because, if there are too few strands, when the load is high, the cables could overload individual cable strands. Six HDD connectors should be considered the minimum. No power supply unit in the test offers fewer connectors anyway. In a system with two hard disks, a CD-RW drive and a DVD drive, this would almost exhaust resources.
It is also considered positive for power supplies to have additional connection options as well. The Global WinTop 420-P4 and Antec Truecontrol 550 products, for example, have additional ports for case fans.
http://www.tomshardware.com/howto/20040122/power_supplies-03.html
9 times out of 10 when some dummy buys a PSU and can't get it to run on 400w and goes out and buys some 800w PSU its because he doesn't know how to divide up his hardware properly.
This problem does not sound like a power supply problem.
From the sound of it, there is something causing interference with the monitor. Look for anything electrical in the area of that part of the monitor and move it.
The other thing it could be is the resolution and refresh rate the monitor is running. Even though the monitor may support the resolution and the refresh rate you are running, it may not display it correctly causing the problem you are describing. You could try lowering the refresh rate or raising it if the monitor will handle that and see what happens.
Should be plenty.
And I am one of the few people on here that truly do need to have a monster PSU. 5 HDDs, PCI SCSI, PCI sound, AGP vid, 2 CD-ROMs, 5 USB powered devices, heavily overclocked processor, 4 sticks of RAM, etc.
If it is name brand like Antec, then yes it is enough.
Thanks for all your responses. I am running a DUAL Monitor setup, each monitor connected via a BNC to the back of 9800XT (VGA and DVI, with a DVI Converter obviously).
The thing is when I had my 9800 PRO, I never noticed this anomaly, just when I switched to 9800XT.
Also worth mentioning is that I have Logitech Z680 5.1 Speaker system, but I doubt if they would cause any MI, since they SHOULD be shielded.
How are those BNC hookups? Are they noticeably better then the normal cables? I've been thinking about getting a Viewsonic 22" CRT that support a BNC hookup but i wasn't even aware what it was until recently. How much did you pay for just the cable? Around $50?
Originally posted by Egekrusher
Should be plenty.
LOL at 5 USB devices. 500ma per port is usual for USB setups. 500ma @ 5v = 2.5w * 5 devices = 12.5w Oh wow! That's some power draw right there :p Yeah the SCSI I understand tho, more power to you ;)
I agree with that artical you quoted, but that's not really what we're talking about. There's no question about daisy channing tons of stuff on one line causing problems, but attaching devices to the connectors already on the wire affecting things down the line?
BNC monitor connections.... this is something I never knew about.. must go research.......
I've actually got BNC connectors on the monitor I use but I never really noticed a difference between the BNC cable and the regular VGA cable. Although having a second cable connected to switch from one comp to another is kind of handy every now and then.
As for daisy chaining the only way it could possibly make a difference would be to try to pull more current through the wire than it can support. Typically 12/14 AWG wire in your house supports around 20A max. Usually you only want to use 80% of it's max current however. In most cases you won't be seeing very much 12/14 guage wire so the numbers will be even lowering. If you replaced the wires with some massive wire you could daisy chain all you wanted if it supported all 40+A on a single rail. The mechanics of fitting said wire into a molex connector is another problem. As long as a single "chain" isn't pulling more than say 10A it's probably fine. Most of it's going into the mobo anyways for the CPU(s) and other parts that one of the drive connectors would seldom be overloaded.
That and if you just make a 20 foot long chain out of a single strand interference on your new antenna could also cause some problems.
