CrimandEvil
Dick with a heart of gold
- Oct 22, 2003
I'm looking to put together a MATX or a MITX SFF and I'm looking for opinions on whether or not I should consider a 1155 build or to build a 1156 one instead?
I want to overclock so that's very important to me and it means I'll need to get one of the K series 1155 CPU's but I really don't relish the fact of having to spend $200+ on the CPU just so I can OC it when I can get a 1156 CPU for a little over a $100 and OC it to 4Ghz or so easy.
If I give up on that I could get a Core i3-2100T (35w 2100) and go with a MITX build in a smaller case. Is the base clock spend enough? Looking for opinions here.
With a 1156 build I have lots of options for either a MATX or MITX build:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157214
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128448
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131599
http://www.newegg.com/Product/Product.aspx?Item=N82E16813500056
With 1155 I have only two options, both MATX, since the IGP H series boards have no support for overclocking.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131708
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131707
So, I have a lot more options with 1156 then I do 1155.
I do have a spare AMD Quad I could use but I need to find a good board for it but I want to wait for Bulldozer compatible boards first.
