iRam $125
You can only install XP on it for vista you need at least 20GB. Don;t bother with these solid state hard drives will take over.
They were supposed to release an update to the iRam that accepted DDR2 and could work with up to 8 gigs of memory. Anyone know what happened with that? I can't find any recent news about it.
I always wanted an iRam to use for my swapfile. Still not worth the cost of the drive and populating it with memory.
Why would you do this when you could just load most motherboards up wit 8GB of RAM and use a 64 bit OS, have faster throughput, and not even need a paging file?
This is not your normal "RAM", its RAM that acts as a harddrive giving you amazing data transfer and access speeds. Windows boots up almost instantaneously.
Great question! There have been long threads about this in the past. There are few applications where you need fast disk-based storage instead of more RAM.
Just the same, I've thought about getting one of these to do some experiments. Which version of the card is being sold at the link given above? The earliest revisions had some serious problems, IIRC.
this is were you are wrong my dear sir. the copy of vista i am using as i type this is installed on a 10gb partition, of which only 7 or so gigs is occupied by vista
It needs to NOT be a plug in board, use a power connector instead.... so it can be placed anywhere, not wasting a PCI slot. (Since it only uses PCI for 3.3V source.)
It needs to have 4 DDR2 slots, and 2 SATAII inputs. So it can pretend to be one or TWO sataII drives. put 4 GBs of DDR2 on ($130) and have it pretend to be a pair of sataII drives in Raid0 PINNING dual sataII controllers at the maximum 300MB's transfer rate.... ie: 600MB/s!!!
Now you have a readyboost... or pagefile... etc, etc.
And it needs to be $49 :eek: :p :D
That would be nice. Anyway this is a pretty cool device. I would pick one up if I still had the ddr it needs.
Yeah the problem with the iRam is suddenly DDR is darn near 2x more expensive than DDR2
Does it actually act as a disk drive and would you have to install WinXP on it?
I have seen some info and it is fast but I haven't seen much on how to actually use it.
Yes, it actually acts as a disk drive. It has a SATA interface. Have to install WinXP on it in order to do what?
there is a "new" version of this comming out. However all that they did was move it to a 5.25 drive bay and give it molex instead of pci for power.
IMHO this could be a must have product if they did some of the following in order of importance. The first three are easy as pie to do and only need new chips on the board itself:
1) change to ddr2
2) change to sata2 for faster max transfers; 300mb/s up from current 150mb/s cap.
3) increase max memory to from 4gb to 8gb so it could better be used for vista baised computers. They could do this either through a new chip or adding a second chip and adding four more slots to the back of the board. If they tired the second method they could even have each 4gb set act as sperate HDDs. If they have 2 sata connectors they could even enable raid0 if you dont need the 8gb but want it to run faster. Regardless this would give the Iram more much needed flexability.
4) use pci-e for data and power with a sata connector to initially install windows on it before you can install the pci-e drivers for the device in windows. This would give a massive increase in bandwidth but would be hard to implement in drivers.
If gigabyte could pull #4 off then this would be a must have device. If they pulled off 1-3 then it would be worth buying for most enthusiasts. As it stands now there is almost no reason to have this device and if you are one of the few that would want this, given its negatives, then you should already know all about it.
its around but expensive as crap and not necessairily better then a normal latop hdd for general use in current incarnations.
If it was truly a proper RAMdisk powered device, it wouldn't hamstring itself by coupling it to the ridiculously slow ATA controllers. I still can't figure out why they designed this thing with that in mind, it makes no sense to me.
Someday we'll have true solid state storage that works at native speeds, meaning it makes ATA and even SATA II stuff look like it really is standing still.
Don't believe the hype: the card is recognized as a "hard drive' by the system and it operates along ATA specifications, so the dreams of loading IE in .1 second are just that, still dreams. Better off getting 4GB of real system RAM in your boxen and using proper RAMdisk software from SuperSpeed.com - point all your temp variables and Temporary IE files to it and then you'll be talking speed.
But then I've been doing that for years and years now. :)
How would you have designed it?
Let the device be recognized for what it is: a RAM expansion and controller basically.
If you can add a video card and that video RAM on the card can be accessed using AGP style reads/writes or using the PCI-E technology which is working basically the same way, why would it be so difficult to create an add-on card that's used for RAM expansion and connects directly to the PCI-E bus and can work at native or near-native PCI-E bus capability speeds?
I mean, theoretically it would be possible right now to take video cards with 256MB or more RAM (can be any amount, I'm just using the high end card RAM amounts as an example) and rewrite or modify the drivers for those cards to allow for the video memory on them to be assigned for just such purposes, go figure.
If the computer can offload the GUI interface directly to the video GPU, and some applications can even offload number crunching duties directly to the GPU (Maya 3D, ATI's Avivo video converter that can use the GPU to actually encode h.264 video incredibly fast, etc), it should be entirely possible to offload RAM duties to that same very high speed video RAM that's not in use at any given time.
All these things are entirely possible, today, right this moment in time, but only one or two of them are actually being done.
Wonder why that is...
Wouldn't that be awesome? Having a video card you paid a month's salary for, with 512MB or more of super high speed DDR3 RAM just sitting there as you're surfing the web acting as a proper RAM-based cache for all that temporary data from your browser, knowing that it can be accessed hundreds of thousands of times faster than any hard drive technology known to man at our present state of technological development?
Talk about adding value to the hardware, geez... if only someone would actually make this stuff a reality, things would be a lot more fun.
^^ ya the only connectors faster in a computer are SCSI and PCI-E 4x and up. AGP would also work but who would give up an AGP slot for this thing?
What I personally want from this device is the fastest OS drive possible and video card ram would not be adiquite for the kind of OSes that I would want to run.
Ok at this point are SSHD's using a SATA connector? Or are they using an all new connector and we have to buy a new controller for them?
Problem is that accessing this memory effectively isn't as straight-forward as you think.
At one extreme, there are video cards with 768 megs and 1 gigabyte of space. These tear a huge hole in the virtual address space of the processor; that memory can't be used for anything else. It might as well be system memory.
At the other extreme, you might implement the device so that it only takes one byte of mapped memory, but that means transfers to it have to g a byte at a time, and end up being (comparatively) slow.
So you have to find some happy medium. Maybe it's 64 or 128 or 256 megs, and then you end up bank switching over that memory area. This is just history repeating itself; it's how I wrote a RAM disk for EMS memory more than twenty years ago.
The memory, through that window, is accessible in one shot -- and you can move that window over the total available memory on the device in another operation.
It's not quite as simple as you're saying, but it's certainly possible. Thing is, instead of going through all this trouble, why not just go to a 64-bit operating system and do it all with system memory?
I was using RAMdisk on Amigas back in 1985 so yeah, the concept ain't new that's for sure. Hell, I could cold boot the machine off the Workbench floppy using the custom config I'd created which would preload the OS components into RAM (Amigas did Prefetch in 1985! hehe) and then I could soft/warm boot the machine from the RAMdisk. That was fun times, I tell ya.
As for why not do it all from system RAM - it's called "RAM is still expensive." It's getting cheap, but every single time RAM has dropped to low prices just like it's doing right now, something happens. It could be a war breaks out, it could be a tsunami smacking into some foreign country that has a chip making plant, whatever. I don't know what's going to happen but rest assured, this low priced glut of RAM won't last much longer, and then it'll skyrocket right back up to where it was before, about $100 a gig or someplace close to that range.
Everything I mentioned in that earlier post is entirely possible and practically applicable right now today, with the hardware that most people have in their machines as they're reading this post, it just takes a smart coder to bring out the abilities in the hardware.
Wonder where that 12 year old supercoder is living... :p
alright ive seen these in past deals around here. my question they just take regular ddr ram?
so with one of these and say two 1gb sticks of ddr ram i would boot into windows and all apps faster than before?
Yes. The product page linked in the original post explains what type of memory the device takes, as does the product page on the Gigabyte website.
It's not quite that simple.
To boot from it? :)
Thanks for clarifying your question. You'd need to install Windows onto it if you wanted to boot from it, yes.
I'm not suggesting that RAM drives are an old concept. I'm pointing out that bank switching isn't a new concept.
Are you assuming that RAM which would populate this device is cheaper than RAM which would populate system memory? That's not the case for this device, and certainly isn't true for the Samsung flash disk drives that are appearing in some notebooks now.
There are other very important benefits to having more system memory. I disagree with jebo_4jc's assessment that the main problem with this device is the cost of memory -- though it's certainly a big problem. The real issue is that it takes configuration, care, and tuning to get performance from the device. I think some of the questions we're seeing in this thread demonstrate that only a very thin set of users can make good use of such a device.
More system memory, on the other hand, helps out all applications at least a little bit without much tuning. And it provides the flexibility for advanced users to apply software-based RAM-based drives as appropriate.
Huh? Who is that?
many of you are wrong.
sata at 150mb is all you need. with only 4 or 8gb and ur windows loading in 5 seconds, u will not need the 300 or 600mb/s since the increase will be unnoticeable.
Windows boot time is governed more by seek time than it is by STR.
It has an onboard battery. It will hold the info if you unplug your system. Just don't let it sit for a conciderable ammount of time.
It's considered a crap shoot. For many the battery has not worked or failed on very short periods of times... for others the batteries ballooned and hissed.
The best bet is to get a nice good hard drive such as a raptor X, not only will you have something that is more reliable, but the low cost and the little bit of a slower speed will make it worthwhile.
I think a few things need to be clarified:
1) The iRam only improves performance for things you put on that drive. So if you want the performance boost in Windows, you have to install Windows on the iRam. If you want <insert long-load-time game here> to load levels faster, install it to the iRam.
2) The iRam only improves performance in the area of reading from or writing to the disk. It won't improve your FPS.
3) As mikeblas said, the iRam makes the biggest difference where seek time is important. So it's better when you're using lots of smaller files than one big file.
4) For multitasking, you'll be better served by spending the money on more system memory. More system memory means less need for a swap file, which means less impact from a RAM-based drive.
I imagine that the engineers and marketing people at Gigabyte chose a SATA interface for a good reason: compatibility. By using a SATA interface, they get a reasonably fast bus (c'mon, 150MB/s is nothing to sniff at), and no need to develop or maintain drivers. This, I think, is a huge bonus. It is, quite literally, as plug-and-play as any hard drive. No need to install special drivers or anything--it just works.
I'll be honest--I want one. And if they came out with a DDR2 version of it right now for $125, I would snatch it up, fill it with DIMMs, and enjoy the fast boot and load times.
