0ptional
Don't Trust Your Friends with Your Decanter
- Feb 22, 2003
omg all the re-springs. messages is infuriating lol.
No way in hell am I putting beta anything on my iPhone 8. I’m guessing something in the ToS says they don’t have to honor their warranty if a beta iOS bricks my phone.
https://www.engadget.com/2018/08/31/apple-ios-12-beta-notification-update-bug/
Anybody else experiencing this?
Had that same update notification bug starting to pop up today, but then there was Public beta 10 that seems to have fixed it.
Thanks for the update. I guess my iMac is losing support as well. Which is irritating as I always felt that the 6970 should've received Metal support from the beginning. It's an arbitrary line in the sand.
Really? You guys got a link on this info?
I'm surprised to see any Intel based Mac go off MacOS support.
Sounds like a driver thing. Killing machines off over a driver is BS if you ask me.
iOS 12 GM released to developers.
Hopefully it will be released to the public in a week. They did that with the Iphone X and IOS 11.
12.1 Public Beta is available.
How long have you had it installed on the device? I've read that at first it chews through the battery while doing some sort of indexing. I only installed it on my ipad, but I haven't noticed a change from iOS 10.3.3iOS 12 for me so far has been about a 25-30% battery life reduction. I have a 6s for a specific and repeatable use and from 100%, with low battery mode on, I could squeeze about 4.5 days out of it on iOS 11. With 12 I barely hit 3 days.
I installed it on the 6th or 7th of September, when the GM leaked out. I would agree that after the first or second charge it kind of finds the steady state of charging after iOS updates, that's why I waited a month to post because I wanted to give an opportunity.How long have you had it installed on the device? I've read that at first it chews through the battery while doing some sort of indexing. I only installed it on my ipad, but I haven't noticed a change from iOS 10.3.3
On my phones, I'm sticking with 10.3.3 for now, though I will sell the 6 once i activate the XS Max.
Mine has 8m, but I don't know what that means, because clearly my iPad is off more than 8 minutes a day (and, for that matter, more than 8 minutes most hours), so I really don't know what it means.I installed it on the 6th or 7th of September, when the GM leaked out. I would agree that after the first or second charge it kind of finds the steady state of charging after iOS updates, that's why I waited a month to post because I wanted to give an opportunity.
I do notice that under battery "screen off" always says 0. Is that normal?
To update my own post, I did a settings reset on the device (without wiping data) and set my power saving settings back up. I seem to be back up to about 4 days per charge now.I installed it on the 6th or 7th of September, when the GM leaked out. I would agree that after the first or second charge it kind of finds the steady state of charging after iOS updates, that's why I waited a month to post because I wanted to give an opportunity.
I had an issue where using the GPS would cause data go die. I could reboot or go into airplane mode for a while and it'd come back. Ended up backing up my phone and doing a restore to the same image. I may have done a factory reset in between, but given that I was using the same settings, I have no idea why that fixed it.To update my own post, I did a settings reset on the device (without wiping data) and set my power saving settings back up. I seem to be back up to about 4 days per charge now.
