inverted motherboard case
Orddie
Hey all,
I have been looking around the forums and saw a few of you with a cae that has 120mm fans at the botom of the case blowing cold air in, and the motherboard mounted @ the top of the case with usb and other io ports @ the top of the case.
Can any of you link the case on neweegg or amazon? I fail at google.
You mean the silverstone raven/fortress cases? They have the i/o ports of the motherboard at the top. You could alternatively buy a case with the flat front and place it on the front. :D
nice work dude.
SILVERSTONE RAVEN RV02-BW is what i talking about. should cool my cards nicely!
What about water cooling for CPU? Do you put one case over another? Currently my ATI cards do NOT have a water block made for them.
Which cards do you have? If there are none for it usually the universal blocks will fit.
Watercooling for a CPU can be done in that case, there are 2x180mm fas at the bottom, that with some slight modification could take a 360 radiator, or a 240mm could be mounted at the front. Theres quite a few people that have mounted water cooling in that case! Search around on the water cooling subforum and you'll find one!
FT02 is best imo, unlike other models this is aluminium unibody + steel frame. Very little plastic in that case (only top panel mesh).
ati hd5770.
