Internet Explorer Bug?
warcraft50
I've been at this for a while and I still get no where. This works in fine FireFox, and IE 5.5. But will not work worth a damn in IE 6 XP SP2. If I goto to: www.microsoft.com and click on "Clip Art" or "Templates" I've got a redirect to the correct page mabye once, every other time it does NOT work.
The address for Clip Art is: http://g.microsoft.com/mh_mshp/130
The Template address is: http://g.microsoft.com/mh_mshp/290
The message box that comes up is:
"Do you want to save this file?"
Unknown File Type
office.microsoft.com"
Making a new filetype entry in associations does absolutely nothing. It's something with the browser from what I can tell. I run no filtering software that blocks anything. Security controls are fine, etc. If you further check out where the address for Clip Art leads it's:
HTTP Status Code: HTTP/1.1 301 Moved Permanently
<HTML>
<HEAD><TITLE>Document moved</TITLE></HEAD>
<BODY><H1>Object Moved</H1>This document may be found <A HREF="http://office.microsoft.com/en-us/templates/default.aspx">here</A>
</BODY>
</HTML>
Ever since I've installed SP2 for XP I've had this problem. There are no updates for IE/patches that I don't already have either. That same box keeps coming up with the "Save File" when it's SUPPOSE to redirect to the link. Any ideas? Thanks
OMG!! a BUG in Winblows!!!
that is practicaly UnHeaRd of!!
what a SuPriZe!!
who would ever have thought this day would come...
use a real OS..
I dunno. No problems w/ IE6/SP2 for that page on my end. In this particular case, have you just tried the URL supplied in the error page?
//edit: also, you might consider attempting to reinstall IE if you're set on using that, or switch to a better and more secure browser like Firefox or Opera
As for the above... thank you for being useless. You've just made my ignore list.
I agree entirely.. that post couldn't possibly have helped Anyone :) haha
but.. i ALso agree about using a better browser.. as IE has got proven major security flaws that are Still unresolved, and Firefox or Opera are a lot quicker also...
Firefox is entirely free though, and part of the GPL, and so i fully suggest anyone using IE at least give it a try..
warcraft50, it sounds as if the file association for a .aspx is not present on your computer.
I tried it on a computer at my home with SP2, and both links worked fine.
Try this.
Start > Run > Type in regedit
expand the HKEY_CLASSES_ROOT folder, and browse down till you find .aspx
If you Do not have a folder for this (which is one of my guesses), then that means windows consideres it an unknown File type, and just tries to download it.
There should be a folder called .aspx if there is'nt, create one.
In that folder, there should be 2 REG_SZ items.
Name: (Default) Type: REG_SZ Data: (value not set)
Name: PerceivedType Type: REG_SZ Data: text
There also might be a sub folder to .aspx called PersistentHandler , but im not sure if that's required.
~Hope this helps, and keep us posted.
Thanks for all the replies everyone. I checked in my proxy settings for the hell of it, and it was using 127.0.0.1:8080 ..I found a copy of a popup blocker installed, I deleted it a couple days ago, or so I thought. Works fine now!
Thanks Again All.
