Internet connections and various chipsets
I'm just wondering what you people think of going with an Asus A8V-E SE with the VIA K8T890 chipset to avoid the Nvidia firewall. I read even if you don't install it, it installs itself and always impacts your Internet connection. I already have Zonealarm so I don't want a second firewall to impact my connection. It sucks. :eek:
By the way, I wonder if that mobo can work well with a 1T command rate with 2X1GB of OCZ Platinum RAM. I have an Athlon 3700+ socket 754 on an Asus K8N4-E Deluxe with that RAM and I was thinking of going with an Athlon single core 4000+ and the same RAM on a Asus A8V-E SE to see if that would work better. I've had random crashes that I suspect might be caused by the 1T command rate. I'm too cheap to get a Core 2 Duo and besides, I already have that expensive RAM.
You can turn the firewall off in bios with Nvidia chipsets.
you would be alot better off with the nvidia nf4 939 board. I had the same asus board as you and I upgraded to the asus a8n-e and a 3200 venice and this thing flies. Im running an o/clock of 550 mhz with stock volts on cpu and ram also with 1T timings with the ram.
My cpu runs at 2550mhz 1 to 1 with ram at 250 htt and 1T timings. Its detected as a 3800+. You can but this cpu and mobo for 58.00 cpu and 78.00 mobo and what a deal it is for that price. It runs so much better than the k8n4e dlx w/ 3400 i had.
look into this as its a cheap option right now and the only other thing to consider is im running corsair xms 3200c2 ram 2/512 sticks. im running settings of 2.5,3,3,7 1T.
this is the finest running system ive had in a long time its fast and stable as a rock.....
think about it.....................
I never thought of that, thanks.
Oddly enough, I did order an Abit NV8 which I haven't installed yet because I haven't formatted my HD yet. Do you think having the Abit NV8 with the 3700+ and 2x1GB OCZ Platinum will help or am I just better off with a socket 939 so I won't have problems with the 1T command rate?
