International student building a computer from scratch
wahoyaho
Hi guys, I'm an international student and I'll be moving to the US for graduate school in August. I'm thinking about buying a new computer from scratch for when I get there, and this is what I have so far.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=20892707
Any comments and/or suggestions and advices are welcome. Thanks!
PS: I plan on getting the I5 2400 for ~$157 at MicroCenter when I arrive.
A little bit of everything, little bit of gaming, entertainment (music, videos), work, web, etc
Trying to keep it as cheap as possible while have acceptable name brand components. Definitely trying to keep it under 1K.
3) Where do you live?
I'll be in Boston, MA
Pretty much everything I have in my wishlist, unless I missed something essential for the computer to run.
None.
6) Will you be overclocking?
Light overclock for GPU probably.
I'm using 22" 1680x1050 right now and haven't really found a reason to get a 1920x1080 monitor yet. Maybe someone can convince me otherwise?
Next month, August 2011.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Anything extra is just a bonus.
Yes, Windows 7 64bit
Lycidas
A month is a long time away, especially since new deals will be posted come August and what we recommend now won't be the same as next month. Bump or re-create the thread with 2~3 weeks before buying at most :D
tonytnnt
The combo deals between now and then will change. You'll want to wait until Newegg's August combos come out to get final pricing.
In the meantime, to give you an idea of specs, you're probably looking at something roughly like this:
$150-$180 -- Microcenter Core i5 2400/2500k
$120 - Some P67 or Z68 motherboard
$50 - 8GB DDR3 1333 RAM
$200 to $250 - Radeon 6870 to GeForce GTX 560Ti or Radeon 6950 (depends on pricing and budget)
$60 - case (HAF 912 or similar)
$60 - 1 TB 7200 RPM hard drive (Samsung F3 usually)
$60 - 100 good power supply (probably a 600 to 750W unit)
$20 - DVD burner
Total: $750 before shipping/taxes
Leaves room for an SSD boot drive, a good monitor, etc. I guess you'll need a keyboard and mouse too, but that could be anywhere from $20 to $100 depending on what type you want. And who knows, maybe the combo prices will be even lower next month.
