Hi everyone,
I'm new to these forums, at least as a registered member. As the title states, I'm having some issues with finding an internal Bluray player that will fit into my X-QPack2 case. I went to Frys yesterday and bought an LG Bluray/HD-DVD drive and went to put it in and found that it was too long, in order for it to fit I would have to remove the sata cable. I have a Samsung DVD drive in there that fits perfectly, its 6.5 inches in depth and all the Bluray drives that I have seen are a bit deeper.
I have a SilverStone modular psu that works great, its a SST-ST60F. I've contemplated in getting a smaller one, but I think its pretty small to begin with. Plus, I really want to stay with a modular psu to keep the amount of cables dangling around to a minimum.
As far as going with an external, my options go up in price and loose out on the HD-DVD option unless I go with the OWC Mercury Pro, which has a bigger price tag. Also, I'm moving to Australia soon, so the 220 volt switch might be a problem as well.
Any advice would be greatly appreciated. Let me know if you need more info or some photos to help illustrate the problem.
Eric
edit: Just in case there is a thread out there dealing with this issue, I apologize in advance. I've done all the searches I could think of.
Eric
