Interesting problem... need help.
Viper87227
I normally don't have to ask for help when I am having problems, but my first shuttle is being a real pain. I got a SN95G5V3 (NF3) and in it is a 3800+ dual core. Now, when i first power it on, the cpu is reporting stupid high temps. Like upwords of 100C. Now, logic tells me this is no where near true, as this CPU would cease to exist at 100C, so my guess is that ive got a pre-dual core support bios and its just getting a funky reading from the CPU. The problem is that auto shutoff keeps kicking in because it thinks its so hot.
So, I figured I would try to update the bios and pray it made it through before autoshutoff kicked in (i could usually make it 5 minutes or so, so figured i would be fine). SO i download the latest bios and awardflash, and throw them on a floppy. Went to flash, and awardflash is telling my my bios file is not an awardflash bios.... yet when I turn the PC on it sasys award bios clear as day at the top of the screen.
Anyone got any suggestions as to what I could do to get this system working?
Maybe it is so hot?
I think you should double check that the HSF is properly installed with the thermal solution applied properly. Maybe even put your hand near the HS see if you can feel high temps.
I had one of these make sure you are gentle with the heatpipe if you have to remove it
Shameless Liar said:
Maybe it is so hot?
Tried that already. The heatsink is secure, it cant get any tighter. Using AS5, enough to make even contact. The oddest part was that shuttles use a heatpipe cooler, and the heatpipes werent so much as warm, which struck me as a little odd.
However, I see no possible way that temp could be correct. If this cpu hit 100C, 212F, aka the bioling point of water... there would be nothing left. It would probably go up in smoke.
Watch itWATCH IT WATCH OUT WATCH OUT
Removing the heatpipe can damage the CPU if you have too much theral compound on it. run the cpu for a few minutes let the thing heat up to loosen the themal compound.
I would let it run without the fan for a few seconds and then remove the heat pipe. Sometimes if you put too much paste it gets hotter than if you just use a littel. I am using as5 and all i do is use one drop (learned this in another thread) and it does keep it cooler.you only need a drop to make contact.
Thats all I used. Trust me, this ain't my first rodoe ;). Which is why I am so confused. Never seen anything like it. But I am still 100% confident the chip is nont running at 100C. As I said, it would be up in smoke.
Help Help Help
I have the Gigabyte GA-K8N51GMF-9 with onboard graphics. I will be playing half-life and doom and alot of the tom clancy war games also nba live and such. Will onbaord graphics of this motherboard be okay?? if not can you recommend a good pci-express card to buy. my budget is 165 bucks and I need to get it from one of the following stores locally or on the web if it has good shipping and handling costs:
www.compusa.com
www.bestbuy.com
www.microcenter.com
or anohter web retailer you reccomend that has good service. Please help.
also note I will use this as a gaming rig and htpc. I have the antec aria case and the amd 84(939pin) 3200 cpu.
New AMD 64 (939 Pin)/Antec Aria Case what CPU heatsink will work
I just got the (1)Gigabyte GA-K8N51GMF-9 Motherboar
(1) AMD 64 3400 (939 Pin) CPU
I am going to install them into the Antec Aria Case. Now here are the issues/Can anyone help?
The stock CPU heatsink will fit the mohterboard and in the Aria but I have heard that the Zalaman heatsinks are better at cooling and much quieter. I purchsed CNPS7000B-ALCU LED
The warranty on the CPU says that I will void the warranty if I install a heatsink other than the one that came in the retail package with the cpu.
I have heard stories of the zalman heatsinks moving or shifting while transporting your pc to other locations. i will be using this rig as a gaming (Lan party) machine and a HTPC should I be concened is there a modified way to install the zalman to keep it from shifting. Please help....
Thank you so much
wow that was the most blant thread jack ever
but yea the CPU would be very unhappy at 100c it COULD be right if you damged it heat pipe
but as you said this isnt your frist time at this so im going to guess thats wrong id pull the chip and try another just to see
THe only onther s939 chip I have readily available is an opteron. If it doesnt support a dual core cpu its certainly not going to support this.
