Intel to Launch Atom N450 in October
HardOCP News
[H] News
DigiTimes, citing anonymous industry sources, claims Intel will launch the Atom N450 in October.
Codenamed Pine Trail, Intel's 45nm Atom N450 will be a single-core CPU with built-in northbridge functions, and will be paired with the new NM10 (Tiger Point) chipset. Intel will issue last order notice for the Atom N270 in the first quarter of 2010 and the CPU will phase out before the end of the first half next year.
Why is intel reverting to single core processors? This sounds like a bit of a regression to me.
I started reading hopefully, then the moment I read "single-core" I grunted in dismay.
I know we're the [H]ard core group of computer users, but not everyone is.
Look at how many buy single core netbooks. Embedded x86 applications often don't need a second core, a single core will usually be enough for them where lower power consumption is important.
I'd like to see a dual core version though, it would make for a nice small HTPC
Atom was never intended for end user PC's. It was intended for embedded applications. Intel is going to be releasing more CULV versions of the Core2 CPU (5-13W). Those will be what laptops and netbooks will use. Can you imagine a Core2 dual core at 1.6GHz on 32nm? A power saver and also powerful. Who needs Atom?
Intel isn't reverting back. This is only to replace the N270. And to get at last rid of that old northbridge and move on to a new chipset.
It will be interesting to see how much the power consumption will be cut when Intel move on making Atom with a smaller process, though this is still on 45nm.
Yes, for ultra portable laptops, but "netbooks" is going still to be using Atom. They want to limit the specifications because manufacturers are afraid that netbooks would otherwise eat market share from more expensive laptops, their profit would go down.
I'm no fan of Atom, a culv core2duo on a newer chipset would be awesome. Wait for Clarkdale/Arrandale.
Uh, what's wrong with this? There is a strong ultra-portable and netbook market. I have an Atom in my Acer Aspire One and it does web browsing, office software etc. just fine. As a student I couldn't really ask for a better portable system considering the price (there are better ones but they tend to get into the $600-700 range, which probably excludes them from actually qualifying as netbooks).
I could see Intel making this move to stifle Nvidia's Ion platform. Right now they are charging more for the Atom if it isn't coupled with their north bridge to make the cost higher to go with Nvidia than an Intel only solution. By putting the two together in one package you are forced to buy the one option.
Talk about anti-competitive tactics, or maybe smart business decisions... depending on who you are.
