What is the motherboard in that build? Since it is a pre-built, it might not recognize newer CPUs such as the Yorkfield line without a BIOS update, if you can find one. See if you can find any documentation stating which CPUs are supported.
Thanks. It is some kind of ASUS so if I can find a Q9650, or and E8400 on the H I will give it a try.
