http://www.engadget.com/2010/09/18/intel-wants-to-charge-50-to-unlock-stuff-your-cpu-can-already-d/
They'd better not do this with enthusiast Sandy Bridge parts.
Why the negative replies? They already downclock (bin) processors to meet demand for lower priced tiers. This just gives the average person a way to unlock performance without swapping processors. You can still do it now, it's just called overclocking, but it can take more work and some experience with hardware.
I predict this concept won't last long. Not only is it a shitty idea, but I'm sure even average joe will figure a way around it quickly as soon as an intrepid programmer releases some sort of "fix" online. Just like every other piece of software meant to lock something down (especially DRM), someone will find a way around it.
Additional elaboration on previous point.
Now, with this option, say 10-years later you still feel the urge to upgrade this particular machine's processor, well you do not need to go through the somewhat involved physical process of locating part and removal/installation. (I still think cleaning up the heat-sink fan is likely needed). All you need is to scratch the paint off the upgrade-card and perform the necessary steps)
...or what if they take a $100 chip, sell it to you for $50 with some stuff turned off and if you want it all, you can buy the $50 unlock. Gosh, that would be terrible wouldn't it.
If you have problem with the chip's missing features, OK, then buy AMD's chip.
Well according to THIS page, you can only upgrade System XYZ sold by retailer 1, 2 or 3. I heard you can get System XYZ with Ubuntu installed from retailer 3, but then you lose the option to do the upgrade to use the hardware you bought.
As long as it stays in the big box stores...whatever. I bet best buy will charge an installation fee. They will come to your house and scratch off the back of that card with a special penny for $100.
As Intel transitions generation after generation, the old stock will decrease until it completely runs out. At that time, even if you wanted to upgrade, you may not be able to find parts easily at reasonable cost. For explanation, just pretend this is the case.
By doing this, Intel does not need to keep old processor stock, yet can continue to offer upgrade for a lot of the old processors. Isn't this grand? I believe AMD, or many other expensive-ware vendors may consider such scheme pretty reasonable alternative, if they are able to pull it off.
Now, finally I have to say the logical thing. This seems like a new trial, so I am not sure who will benefit more down the road. I am not willing to make any claim on this new scheme. This addresses the "good/bad things to do" issue as I have made no judgement on that point. Vendors/customers will decide how this scheme works eventually.
(snip) Who wants to willingly buy a hobbled computer? How does this benefit the consumer? All it does is create yet another pricing tier.
Who wants to willingly buy a hobbled computer? How does this benefit the consumer? All it does is create yet another pricing tier and thereby increases overall cost for the consumer to get the same level of performance previously.
Everybody that buys a Celeron based PC, that's who. It's nice that those people can pay for a Celeron today and upgrade to a "flagship" down the road if they need to do so. All the end user has to do is punch in a code, no tech service required.
I think I'm only one of the few who are completely OK with this.
Any body who doesn't buy the highest tier CPUs is already buying hobbled computers. The hardware is the same, but the microcodes which operate the lower end chips simply reduce the clock rate and cache of lower end chips. Physically, the hardware on your low or mid range chip is not any different from that of the high end chip. This product, if what we know about it thus far is true, will simply unlock these features and allow us to upgrade our machines without replacing hardware.
It is different. The binning process differentiates different quality chips and a microcode is assigned based on that. (That still is an oversimplification.) They are assigned tiers. My point is the more tiers you have the higher the likelihood of overall cost for the consumer. It's market economics. Instead of Value/Mainstream/Performance at $X, $X+50, $X+100 you have Budget/Value/Mainstream/Performance at $X, $X+50, $X+100, $X+150.
Mainstream and performance users face higher cost if the model is widely implemented.
this would be much more successful is done this way. Buy a chip, spend x amount of dollars to turn your 7, 8, or 9 series I5 or I7 into a xxxK model
What you people who think this is a good idea don't seem to get is that the "hobbled" CPU is the same exact CPU whether or not the "upgrade card" is used.
