Nazo
- Apr 2, 2002
Seems to me like some of these comparisons lack in accuracy though. AMD is inded capitalizing on people's need for a simpler system (eg, "3700+ is higher than 3500+, so I'll just grab that" type of thinking.) However, let's not forget that we should compare more by what they actually ARE. For example, why compare a higher numbered chip based on the San Diego core when you are all but guaranteed an overclock of, say 2.5GHz (I think that's the lowest.) So, if we want to accurately compare, we need to compare real results and their costs. Now, don't get me wrong. Intel may match this too, or, perhaps even come out ahead more noticably for all I could say, I'm just saying we need a more accurate comparison.
Oh, and FPS in a few games is not an accurate test. At all. Too many variables in that. Different chipsets, video setups, etc (I've even once seen a comparison where they used different video cards when comparing two setups using a game test, completely invalidating the entire comparison.) I know people don't like synthetic benchmarks, but, the cool thing about them is they eliminate all the variables that you can eliminate. The main problem is just that if you don't use the right ones you see only one part of what the CPUs can do, so one can look better than it is if say it has a really fast integer but a crappy floating point if the test ignores floating point. I kind of wonder if CrystalMark is a good tool for this since it breaks things down into a lot of various tests (plus, hey, it's free.) d-:
Anyway, I'm an AMD only guy mainly because I haven't kept up well enough with Intel and forget which P4 is which now, plus AMD has just had such great bang for the buck type products (such as my current non FX series, or, better yet, the Athlon XP mobile I used to have which I had oced past the performance level of a processor that cost twice as much.) I've been generally pretty happy so haven't had to go back to Intel just yet. Still, last I heard, Intel and AMD have flipped on the temperature area, which seems funny since AMD got such a bad reputation for it's temperatures. Last I heard, modern P4s (excluding the super-low end chips that are essentially a high end chip underclocked) run where Athlon XPs used to or even higher. IMO this is an important factor when choosing a processor. Well, I don't know about ALL the P4s, but, the ones in the priceranges of the people I usually end up recommending hardware for are the hot kinds usually at least. I have to say, my current CPU, overclocked and with raised voltage (ok, only a bit raised) runs cooler than my grandmother's old original technology P4 2.4GHz or the ancient P3s I have in the second system in my signature, and neither of those systems have overclocking. 38C is the highest I've caught it doing with a little help from MPEG2 encoding and me having left the AC off too long, and it idles at ambient, compared to my grandmother's non-oced P4-2.4 sitting around 31C idle minimum (I'm not sure of the direct effects of ambient, but, the CPU is at least 5C above ambient.) That's the old technology that was known for being cool. Are there any new ones that run cooler? The people I recommend hardware for are the kind who don't understand about cooling and are willing to run a PC in a room with no AC during the summer, so it has to take some punishment (I can't do anything for memory since most of them are insisting on pre-built systems and the manufacturers are too lazy to tell you what memory, motherboard, or any other useful information.)
