InorganicMatter
- Oct 19, 2004
I always find it ironic when the tables turn. AMD guys have always said that AMD was the better choice because you could buy it for less than Intel and then overclock it to be faster than the more expensive Intel. Observe:
http://www.driverheaven.net/reviews/fx60/quake4.htm
http://www.newegg.com/Product/Product.asp?Item=N82E16819116240
http://www.newegg.com/Product/Product.asp?Item=N82E16819103608
$250 difference...for two extra frames...and the Intel can easily be overclocked to outperform the more expensive AMD.
Is my logic correct? Flawed? Discuss.
I put this in Intel Processors since a flame war is almost gauranteed if I put it in the correct forum (AMD), but if the mods think it should be moved please do so.
