Intel IP35-E (CPU is unworkable or has been changed)
Funcoot
Basically I just finished my build, and when I turn on the computer, everything boots, but one problem. On boot I get a message. "CPU is unworkable or has been changed. Please check - CPU SOFT MENU"
Please help, thanks in advanced!:p
try clearing CMOS and if that doesn't work try reseating the cpu.
Update. Well I saw the ram voltage was set to auto, I upped it to 2.1, which is what my rams voltage is, and now it gets past that. But now I am just skeptic to whether or not I made it worse.
Also, not it asks for a bootdisk, now the problem is I have 2 IDE devices in my comptuter. An IDE harddrive, and an IDE dvdrom. I put the master in the dvdrom and the slave in the harddrive, will that not work?
I haven't messed with IDE items in a while. but try it and see if it works. If not then reverse it.
What about your cpu did you get it fixed?
if not just remove the battery on the motherboard and change the jumper, should be three pins with a connector on two of them. Make sure to change the jumper back, also don't forget to unplug the power supply before doing all this.
I did what you said. Did the whole jumper thing. I boot up with the normal checksum error -defaults loaded. But I get a bootdisk failure, reboot, and I get the CPU is unworkable message.
does your board see your HDD? to check either go to Standard CMOS Features or Advance BIOS Features > Hard Disk Boot Priority. your HDD should be listed.
for the CPU error, like i said earlier, try reseating it. meaning remove the heatsink, take the cpu out and put it back in.
update your bios, a prior earlier bios wont boot properluy if your ram is set at 1.8 and needs to be set to 2v or higher.
also you can get that error if you overclocking it / change settings and it doesnt stick / work
CPU is unworkable or has been changed is a normal message on a newly installed abit or after clearing CMOS.
Select load optimised defaults (change your Vdimm if required), save & exit & it should be gone.
That should work. But a couple of "gotchas"
I am assuming you mean you set the jumpers on the back like you said above and if so you must put the dvdrom on the connector on the end of the cable and the hardrive on the middle connector.
Also some hard drives do not like the secondary/slave jumper setting. It should not matter but sometimes it just does. If you are still having problems try setting the jumper on the HD to cable select (CS) and leave it plugged into the middle connector.
If you cable is new (and it should be for high speed operation) it should be color coded.
Blue: The blue connector attaches to the host (motherboard or controller).
Gray: The gray connector is in the middle of the cable, and goes to any slave (device 1) drive if present on the channel.
Black: The black connector is at the opposite end from the host connector and goes to the master drive (device 0), or a single drive if only one is used.
Well, I am not sure if it is picking up my DVDdrive either. When I boot, it says it is detecting 0 drives. I think I will make this easier on myself and pickup a sata DVDdrive and sata harddrive.
I got this last night when I put my machine together...But it only happened once...never got it again..
